ActiveX 开发指南
相关分类
XRefDemandLoad Property (ActiveX)
2023-1-3 00:55| 发布者: admin| 查看: 1557| 评论: 0|来自: AutoCAD
摘要: 指定外部引用的需求加载。
指定外部引用的需求加载。
支持的平台:仅窗口
工 务 局:
object.XRefDemandLoad
类型:首选项打开保存
此属性适用的对象。
只读:不
类型:枚举acXRefDemandLoad
  • acDemandLoadDisabled:关闭需求加载;将加载整个图形。
  • acDemandLoadEnabled:启用按需加载并提高 AutoCAD 性能。其他用户无法在引用文件时对其进行编辑。
  • acDemandLoadEnabledWithCopy:打开按需加载,但使用参照图形的副本。其他用户可编辑原始图形。
按需加载通过仅加载再生当前图形所需的参照图形部分来提高性能。
此属性的初始值为。acDemandLoadEnabled
注意:此属性的值存储在 XLOADCTL 系统变量中。
工 务 局:
Sub Example_XRefDemandLoad()
    ' XRefDemandLoad. It then changes the value, and finally
    Dim currXRefDemandLoad As Integer
    Dim constant As String
    Dim newConstant As String
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current XRefDemandLoad value
    currXRefDemandLoad = preferences.OpenSave.XrefDemandLoad
    constant = Choose(currXRefDemandLoad + 1, "acDemandLoadDisabled", "acDemandLoadEnabled", "acDemandLoadEnabledWithCopy")
    MsgBox "The current value for XRefDemandLoad is " & constant, vbInformation, "XRefDemandLoad Example"
    ' Change the value for XRefDemandLoad
    newConstant = "acDemandLoadEnabledWithCopy"
    preferences.OpenSave.XrefDemandLoad = acDemandLoadEnabledWithCopy
    MsgBox "The new value for XRefDemandLoad is " & newConstant, vbInformation, "XRefDemandLoad Example"
    ' Reset XRefDemandLoad to its original value
    preferences.OpenSave.XrefDemandLoad = currXRefDemandLoad
    MsgBox "The XRefDemandLoad value is reset to " & constant, vbInformation, "XRefDemandLoad Example"
Visual LISP:
(defun c:Example_XRefDemandLoad()
    ;; XRefDemandLoad. It then changes the value, and finally
    ;; Retrieve the current XRefDemandLoad value
    (setq currXRefDemandLoad (vla-get-XrefDemandLoad (vla-get-OpenSave preferences)))
    (setq constant (cond
                       ((= currXRefDemandLoad acDemandLoadDisabled) "acDemandLoadDisabled")
                       ((= currXRefDemandLoad acDemandLoadEnabled) "acDemandLoadEnabled")
                       ((= currXRefDemandLoad acDemandLoadEnabledWithCopy) "acDemandLoadEnabledWithCopy")
    (alert (strcat "The current value for XRefDemandLoad is " constant))
    ;; Change the value for XRefDemandLoad
    (setq newConstant "acDemandLoadDisabled")
    (vla-put-XrefDemandLoad (vla-get-OpenSave preferences) acDemandLoadDisabled)
    (alert (strcat "The new value for XRefDemandLoad is " newConstant))
    ;; Reset XRefDemandLoad to its original value
    (vla-put-XrefDemandLoad (vla-get-OpenSave preferences) currXRefDemandLoad)
    (alert (strcat "The XRefDemandLoad value is reset to " constant))
GMT+8, 2026-10-28 16:11
