指定对象或应用程序的可见性。 支持的平台:仅窗口 属性值只读:否(只写对象除外)Group 类型:布尔
言论如果将对象指定为不可见,则无论应用程序可见设置如何,该对象都将不可见。其他因素也可能导致物体不可见;例如,如果对象的图层关闭或冻结,则不会显示该对象。 通过将应用程序指定为不可见,您可以在后台运行任务,而无需查看组件。 例子工 务 局: Sub Example_Visible()
' This example creates a line in model space.
' It then turns visibility of the line on or off, depending
' on the user's choice.
Dim lineObj As AcadLine
' Create the line
startPoint(0) = 2#: startPoint(1) = 2#: startPoint(2) = 0#
endPoint(0) = 4#: endPoint(1) = 4#: endPoint(2) = 0#
ZoomAll
Dim response As Integer
response = MsgBox("Do you want the new line to be visible?", vbYesNoCancel + vbQuestion)
Select Case response
Case vbYes
lineObj.Visible = True
Case vbNo
lineObj.Visible = False
Case vbCancel
Exit Sub
End Select
ThisDrawing.Regen True
Visual LISP: (vl-load-com)
(defun c:Example_Visible()
;; This example creates a line in model space.
;; It then turns visibility of the line on or off, depending
;; on the user's choice.
;; Create the line
(setq startPoint (vlax-3d-point 2 2 0)
endPoint (vlax-3d-point 4 4 0))
(vla-ZoomAll acadObj)
(setq kwordList "Yes No")
(vla-InitializeUserInput (vla-get-Utility doc) 1 kwordList)
(setq response (vla-GetKeyword (vla-get-Utility doc) "Do you want the new line to be visible? [Yes/No]: "))
(cond
((= response "Yes") (vla-put-Visible lineObj :vlax-true))
((= response "No") (vla-put-Visible lineObj :vlax-false))
(vla-Regen doc :vlax-true)
GMT+8, 2026-11-21 01:03
