指定 3DFace 边的可见性 1。 支持的平台:仅窗口 属性值只读:不 类型:布尔
言论您还可以使用 theand 方法来查询或设置边的可见性。由于这些方法使用索引来指定边缘,因此它们在循环访问面的所有边缘时非常有用。GetInvisibleEdgeSetInvisibleEdge 例子工 务 局: Sub Example_VisibilityEdge1()
' This example creates a 3D Face in model space and allows the user to
' control the visibility of the edges
Dim faceObj As Acad3DFace
Dim point1(0 To 2) As Double, point2(0 To 2) As Double, _
point3(0 To 2) As Double, point4(0 To 2) As Double
Dim Edge1Msg As String, Edge2Msg As String, _
Edge3Msg As String, Edge4Msg As String
' Define the four coordinates of the face
point1(0) = 0: point1(1) = 0: point1(2) = 0
point2(0) = 5: point2(1) = 0: point2(2) = 1
point3(0) = 1: point3(1) = 10: point3(2) = 0
point4(0) = 5: point4(1) = 5: point4(2) = 1
' Create the 3DFace object in model space
Set faceObj = ThisDrawing.ModelSpace.Add3DFace(point1, point2, point3, point4)
' Display information about the visibility of the edges for this object
DisplayEdgeInformation:
Edge1Msg = IIf(faceObj.VisibilityEdge1, "Edge1 of the new 3DFace is visible", "Edge1 of the new 3DFace is not visible")
Edge2Msg = IIf(faceObj.VisibilityEdge2, "Edge2 of the new 3DFace is visible", "Edge2 of the new 3DFace is not visible")
Edge3Msg = IIf(faceObj.VisibilityEdge3, "Edge3 of the new 3DFace is visible", "Edge3 of the new 3DFace is not visible")
Edge4Msg = IIf(faceObj.VisibilityEdge4, "Edge4 of the new 3DFace is visible", "Edge4 of the new 3DFace is not visible")
MsgBox Edge1Msg & vbCrLf & _
Edge2Msg & vbCrLf & _
Edge3Msg & vbCrLf & _
Edge4Msg
' Allow user to toggle the visibility of one of the edges
Select Case InputBox("Which edge of the 3DFace would you like to toggle the visibility of?", "Toggle Edge Visibility", 1)
Case "1": faceObj.VisibilityEdge1 = Not (faceObj.VisibilityEdge1)
Case "2": faceObj.VisibilityEdge2 = Not (faceObj.VisibilityEdge2)
Case "3": faceObj.VisibilityEdge3 = Not (faceObj.VisibilityEdge3)
Case "4": faceObj.VisibilityEdge4 = Not (faceObj.VisibilityEdge4)
Case "": Exit Sub
Case Else: MsgBox "You must enter the number of an edge (1-4)", vbInformation
End Select
' Refresh view
' Return to display information about the edges
GoTo DisplayEdgeInformation
Visual LISP: (vl-load-com)
(defun c:Example_VisibilityEdge1()
;; This example creates a 3D Face in model space and allows the user to
;; control the visibility of the edges
;; Define the four coordinates of the face
(setq point1 (vlax-3d-point 0 0 0)
point2 (vlax-3d-point 5 0 1)
point3 (vlax-3d-point 5 5 1)
point4 (vlax-3d-point 1 10 0))
;; Create the 3DFace object in model space
(setq faceObj (vla-Add3DFace modelSpace point1 point2 point3 point4))
(vla-ZoomAll acadObj)
;; Display information about the visibility of the edges for this object
(setq edge1Msg (if (= (vla-get-VisibilityEdge1 faceObj) :vlax-true) "Edge1 of the new 3DFace is visible" "Edge1 of the new 3DFace is not visible"))
(setq edge2Msg (if (= (vla-get-VisibilityEdge2 faceObj) :vlax-true) "Edge2 of the new 3DFace is visible" "Edge2 of the new 3DFace is not visible"))
(setq edge3Msg (if (= (vla-get-VisibilityEdge3 faceObj) :vlax-true) "Edge3 of the new 3DFace is visible" "Edge3 of the new 3DFace is not visible"))
(setq edge4Msg (if (= (vla-get-VisibilityEdge4 faceObj) :vlax-true) "Edge4 of the new 3DFace is visible" "Edge4 of the new 3DFace is not visible"))
(alert (strcat Edge1Msg
"\n" Edge2Msg
"\n" Edge3Msg
"\n" Edge4Msg))
;; Allow user to toggle the visibility of one of the edges
(setq faceNum (vla-GetInteger (vla-get-Utility doc) "\nWhich edge of the 3DFace would you like to toggle the visibility of? (1 to 4)\n"))
(cond
((= faceNum 1)(vla-put-VisibilityEdge1 faceObj (if (= (vla-get-VisibilityEdge1 faceObj) :vlax-true) :vlax-false :vlax-true)))
((= faceNum 2)(vla-put-VisibilityEdge2 faceObj (if (= (vla-get-VisibilityEdge2 faceObj) :vlax-true) :vlax-false :vlax-true)))
((= faceNum 3)(vla-put-VisibilityEdge3 faceObj (if (= (vla-get-VisibilityEdge3 faceObj) :vlax-true) :vlax-false :vlax-true)))
((= faceNum 4)(vla-put-VisibilityEdge4 faceObj (if (= (vla-get-VisibilityEdge4 faceObj) :vlax-true) :vlax-false :vlax-true)))
(alert "You must enter the number of an edge (1-4)")
;; Refresh view
;; Return to display information about the edges
(setq edge1Msg (if (= (vla-get-VisibilityEdge1 faceObj) :vlax-true) "Edge1 of the new 3DFace is now visible" "Edge1 of the new 3DFace is now not visible"))
(setq edge2Msg (if (= (vla-get-VisibilityEdge2 faceObj) :vlax-true) "Edge2 of the new 3DFace is now visible" "Edge2 of the new 3DFace is now not visible"))
(setq edge3Msg (if (= (vla-get-VisibilityEdge3 faceObj) :vlax-true) "Edge3 of the new 3DFace is now visible" "Edge3 of the new 3DFace is now not visible"))
(setq edge4Msg (if (= (vla-get-VisibilityEdge4 faceObj) :vlax-true) "Edge4 of the new 3DFace is now visible" "Edge4 of the new 3DFace is now not visible"))
"\n" Edge2Msg
"\n" Edge3Msg
"\n" Edge4Msg))
GMT+8, 2026-10-26 09:29
