指定文本相对于尺寸线的垂直位置。 支持的平台:仅窗口 属性值只读:不 类型:枚举acDimVerticalJustification
言论此属性的初始值为。acVertCentered 注意:此属性将覆盖给定尺寸、引线或公差对象的 DIMTAD 系统变量的值。
例子工 务 局: Sub Example_VerticalTextPosition()
' This example creates an aligned dimension in model space
' and cycles the dimension text through a couple of different
' vertical alignments
Dim dimObj As AcadDimAligned
Dim CurrentValue As String
' Define the dimension
point2(0) = 9: point2(1) = 5: point2(2) = 0
' Read and display current text position
Select Case dimObj.VerticalTextPosition
Case acVertCentered: CurrentValue = "centered"
Case acAbove: CurrentValue = "above"
Case acOutside: CurrentValue = "outside"
Case acJIS: CurrentValue = "to Japanesee industrial standards"
End Select
MsgBox "The vertical position of the dimension is: " & CurrentValue
' Change the position of the dimension text to be above the extesnion lines
dimObj.VerticalTextPosition = acAbove
MsgBox "Dimension text is now aligned above extension lines"
' Change the position of the dimension text to be centered with the extension lines
dimObj.VerticalTextPosition = acVertCentered
MsgBox "Dimension text is now centered with the extension lines"
Visual LISP: (vl-load-com)
(defun c:Example_VerticalTextPosition()
;; This example creates an aligned dimension in model space
;; and cycles the dimension text through a couple of different
;; vertical alignments
;; Define the dimension
point2 (vlax-3d-point 9 5 0)
(vla-ZoomAll acadObj)
;; Read and display current text position
(setq CurrentValue (cond
((= (vla-get-VerticalTextPosition dimObj) acVertCentered) "centered")
((= (vla-get-VerticalTextPosition dimObj) acAbove) "above")
((= (vla-get-VerticalTextPosition dimObj) acOutside) "outside")
((= (vla-get-VerticalTextPosition dimObj) acJIS) "to Japanesee industrial standards")
(alert (strcat "The vertical position of the dimension is: " CurrentValue))
;; Change the position of the dimension text to be above the extesnion lines
(vla-put-VerticalTextPosition dimObj acAbove)
(alert "Dimension text is now aligned above extension lines")
;; Change the position of the dimension text to be centered with the extension lines
(vla-put-VerticalTextPosition dimObj acVertCentered)
(alert "Dimension text is now centered with the extension lines")
GMT+8, 2026-11-9 11:15
