获取文档的 UCS 集合。 支持的平台:仅窗口 言论没有额外的评论。 例子工 务 局: Sub Example_UserCoordinateSystems()
' This example finds the current UserCoordinateSystems collection and
' adds a new UCS to that collection.
Dim UCSColl As AcadUCSs
Set UCSColl = ThisDrawing.UserCoordinateSystems
' Create a UCS named "TEST" in the current drawing
Dim ucsObj As AcadUCS
Dim origin(0 To 2) As Double
Dim xAxisPnt(0 To 2) As Double
Dim yAxisPnt(0 To 2) As Double
' Define the UCS
origin(0) = 4#: origin(1) = 5#: origin(2) = 3#
xAxisPnt(0) = 5#: xAxisPnt(1) = 5#: xAxisPnt(2) = 3#
yAxisPnt(0) = 4#: yAxisPnt(1) = 6#: yAxisPnt(2) = 3#
' Add the UCS to the UserCoordinatesSystems collection
Set ucsObj = UCSColl.Add(origin, xAxisPnt, yAxisPnt, "TEST")
MsgBox "A new UCS called " & ucsObj.name & " has been added to the UserCoordinateSystems collection.", vbInformation, "UserCoordinateSystems Example"
Visual LISP: (vl-load-com)
(defun c:Example_UserCoordinateSystems()
;; This example finds the current UserCoordinateSystems collection and
;; adds a new UCS to that collection.
(setq UCSColl (vla-get-UserCoordinateSystems doc))
;; Create a UCS named "TEST" in the current drawing
;; Define the UCS
(setq origin (vlax-3d-point 4 5 3)
xAxisPnt (vlax-3d-point 5 5 3)
yAxisPnt (vlax-3d-point 4 6 3))
;; Add the UCS to the UserCoordinatesSystems collection
(setq ucsObj (vla-Add UCSColl origin xAxisPnt yAxisPnt "TEST"))
(alert (strcat "A new UCS called " (vla-get-Name ucsObj) " has been added to the UserCoordinateSystems collection."))
GMT+8, 2026-10-16 17:33
