应用上一个成功打印的打印设置。 支持的平台:仅窗口 属性值只读:不 类型:布尔
言论没有额外的评论。 例子工 务 局: Sub Example_UseLastPlotSettings()
' This example reads and modifies the UseLastPlotSettings
' preference value.
' When finished, this example resets the preference value back to
' it's original value.
Dim ACADPref As AcadPreferencesOutput
Dim originalValue As Boolean
' Get the user preferences object
Set ACADPref = ThisDrawing.Application.preferences.Output
originalValue = ACADPref.UseLastPlotSettings
MsgBox "The UseLastPlotSettings preference is set to: " & originalValue
' Modify the UseLastPlotSettings preference by toggling the value
ACADPref.UseLastPlotSettings = Not ACADPref.UseLastPlotSettings
MsgBox "The UseLastPlotSettings preference has been set to: " & ACADPref.UseLastPlotSettings
' Reset the preference back to it's original value
ACADPref.UseLastPlotSettings = originalValue
MsgBox "The UseLastPlotSettings preference was reset back to: " & originalValue
Visual LISP: (vl-load-com)
(defun c:Example_UseLastPlotSettings()
;; This example reads and modifies the UseLastPlotSettings
;; preference value.
;; When finished, this example resets the preference value back to
;; it's original value.
(setq originalValue (vla-get-UseLastPlotSettings (vla-get-Output preferences)))
(alert (strcat "The UseLastPlotSettings preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
;; Modify the UseLastPlotSettings preference by toggling the value
(vla-put-UseLastPlotSettings (vla-get-Output preferences) (if (= originalValue :vlax-true) :vlax-false :vlax-true))
(alert (strcat "The UseLastPlotSettings preference has been set to: " (if (= (vla-get-UseLastPlotSettings (vla-get-Output preferences)) :vlax-true) "True" "False")))
;; Reset the preference back to it's original value
(vla-put-UseLastPlotSettings (vla-get-Output preferences) originalValue)
(alert (strcat "The UseLastPlotSettings preference was reset back to: " (if (= (vla-get-UseLastPlotSettings (vla-get-Output preferences)) :vlax-true) "True" "False")))
GMT+8, 2026-10-27 23:54
