指定 UCS 图标是否打开。 支持的平台:仅窗口 属性值只读:不 类型:布尔
言论没有额外的评论。 例子工 务 局: Sub Example_UCSIconOn()
' This example toggles the setting of UCSIconOn.
Dim viewportObj As AcadViewport
' Set the viewportObj variable to the activeviewport
Set viewportObj = ThisDrawing.ActiveViewport
' Display the current setting of UCSIconOn
MsgBox "UCSIcon is: " & IIf(viewportObj.UCSIconOn, "On", "Off"), , "UCSIconOn Example"
' Toggle the setting of UCSIconOn
viewportObj.UCSIconOn = Not (viewportObj.UCSIconOn)
' Reset the active viewport to see the change
ThisDrawing.ActiveViewport = viewportObj
MsgBox "UCSIcon is now: " & IIf(viewportObj.UCSIconOn, "On", "Off"), , "UCSIconOn Example"
Visual LISP: (vl-load-com)
(defun c:Example_UCSIconOn()
;; This example toggles the setting of UCSIconOn.
;; Set the viewportObj variable to the activeviewport
(setq viewportObj (vla-get-ActiveViewport doc))
;; Display the current setting of UCSIconOn
(alert (strcat "UCSIcon is: " (if (= (vla-get-UCSIconOn viewportObj) :vlax-true) "On" "Off")))
;; Toggle the setting of UCSIconOn
(vla-put-UCSIconOn viewportObj (if (= (vla-get-UCSIconOn viewportObj) :vlax-true) :vlax-false :vlax-true))
;; Reset the active viewport to see the change
(vla-put-ActiveViewport doc viewportObj)
(alert (strcat "UCSIcon is now: " (if (= (vla-get-UCSIconOn viewportObj) :vlax-true) "On" "Off")))
GMT+8, 2026-10-27 05:40
