ActiveX 开发指南
相关分类
真彩色属性 (ActiveX)
2023-1-3 02:43| 发布者: admin| 查看: 1485| 评论: 0|来自: AutoCAD
摘要: 指定对象的真彩色。
指定对象的真彩色。
支持的平台:仅窗口
工 务 局:
object.TrueColor
类型:所有图形对象,属性参考,尺寸,组,图层
此属性适用的对象。
只读:不
类型:AcCm颜色
对象的真彩色对象。
此属性用于更改对象的颜色。颜色由对象标识。此对象可以保存 RGB 值、ACI 编号(从 1 到 255 的整数)或命名颜色。使用 RGB 值,您可以从数百万种颜色中进行选择。AcCmColor
工 务 局:
Sub Example_TrueColor()
    ' This example draws a line and returns the RGB values
    Dim color As AcadAcCmColor
    Set color = AcadApplication.GetInterfaceObject("AutoCAD.AcCmColor." & Left(AcadApplication.Version, 2))
    color.SetRGB 80, 100, 244
    Dim line As AcadLine
    startPoint(0) = 1#: startPoint(1) = 1#: startPoint(2) = 0#
    endPoint(0) = 5#: endPoint(1) = 5#: endPoint(2) = 0#
    Set line = ThisDrawing.ModelSpace.AddLine(startPoint, endPoint)
    ZoomAll
    line.TrueColor = color
    Dim retcolor As AcadAcCmColor
    Set retcolor = line.TrueColor
    MsgBox "Red = " & retcolor.Red & vbLf & _
           "Green = " & retcolor.Green & vbLf & _
           "Blue = " & retcolor.Blue
Visual LISP:
(defun c:Example_TrueColor()
    ;; This example draws a line and returns the RGB values
    (setq color (vlax-create-object (strcat "AutoCAD.AcCmColor." (substr (getvar "ACADVER") 1 2))))
    (vla-SetRGB color 80 100 244)
    (setq startPoint (vlax-3d-point 1 1 0)
          endPoint (vlax-3d-point 5 5 0))
    (vla-ZoomAll acadObj)
    (vla-put-TrueColor lineObj color)
    (setq retcolor (vla-get-TrueColor lineObj))
    (alert (strcat "Red = " (itoa (vla-get-Red retcolor))
                   "\nGreen = " (itoa (vla-get-Green retcolor))
                   "\nBlue = " (itoa (vla-get-Blue retcolor))))
GMT+8, 2026-10-17 04:47
