获取圆弧的总角度。 支持的平台:仅窗口 属性值只读:是的 类型:双 弧的总长度(以弧度为单位)。 言论没有额外的评论。 例子工 务 局: Sub Example_TotalAngle()
' This example creates an Arc in model space and
' returns the total angle of the new Arc
Dim arcObj As AcadArc
Dim radius As Double
Dim startAngleInDegree As Double, endAngleInDegree As Double
Dim startAngleInRadian As Double, endAngleInRadian As Double
' Define the Arc
centerPoint(0) = 0: centerPoint(1) = 0: centerPoint(2) = 0
radius = 5#
startAngleInDegree = 10#: endAngleInDegree = 230#
' Convert the angles in degrees to angles in radians
startAngleInRadian = startAngleInDegree * 3.141592 / 180#
endAngleInRadian = endAngleInDegree * 3.141592 / 180#
' Create the arc object in model space
Set arcObj = ThisDrawing.ModelSpace.AddArc(centerPoint, radius, startAngleInRadian, endAngleInRadian)
' Return length of new arc
MsgBox "The total angle of the new Arc is: " & arcObj.TotalAngle
Visual LISP: (vl-load-com)
(defun c:Example_TotalAngle()
;; This example creates an Arc in model space and
;; returns the total angle of the new Arc
;; Define the arc
(setq centerPoint (vlax-3d-point 0 0 0)
radius 5
startAngleInDegree 10
endAngleInDegree 230)
;; Convert the angles in degrees to angles in radians
(setq startAngleInRadian (/ (* startAngleInDegree 3.141592) 180))
(setq endAngleInRadian (/ (* endAngleInDegree 3.141592) 180))
;; Create the arc object in model space
(setq arcObj (vla-AddArc modelSpace centerPoint radius startAngleInRadian endAngleInRadian))
(vla-ZoomAll acadObj)
;; Return length of new arc
(alert (strcat "The total angle of the new Arc is: " (rtos (vla-get-TotalAngle arcObj) 2)))
GMT+8, 2026-11-2 07:06
