指定在容差值中禁止显示零英尺测量值。 支持的平台:仅窗口 属性值只读:不 类型:布尔
言论此属性的初始值为。False 注意:此属性将覆盖给定维度的 DIMTZIN 系统变量的值。
例子工 务 局: Sub Example_ToleranceSuppressZeroFeet()
' uses ToleranceSuppressZeroFeet to toggle the display of zeros feet
' in the dimension tolerance display
Dim dimObj As AcadDimAligned
' Define the dimension
point2(0) = 6.01: point2(1) = 5: point2(2) = 0
location(0) = 5: location(1) = 8: location(2) = 0
dimObj.UnitsFormat = acDimLArchitectural
' Enable and setup tolerance display
dimObj.ToleranceDisplay = acTolLimits
dimObj.ToleranceLowerLimit = -0.0001: dimObj.ToleranceUpperLimit = 0.0001
ZoomAll
Toggle:
Select Case MsgBox("Press OK to toggle the display of zero feet in the dimension tolerance", vbOKCancel)
Case vbOK
' Toggle the display of zero feet for the dimension tolerance value
dimObj.ToleranceSuppressZeroFeet = Not (dimObj.ToleranceSuppressZeroFeet)
Case vbCancel
Exit Sub
End Select
GoTo Toggle
Visual LISP: (vl-load-com)
(defun c:Example_ToleranceSuppressZeroFeet()
;; uses ToleranceSuppressZeroFeet to toggle the display of zeros feet
;; in the dimension tolerance display
;; Define the dimension
point2 (vlax-3d-point 6.01 5 0)
location (vlax-3d-point 5 8 0))
(vla-put-UnitsFormat dimObj acDimLArchitectural)
;; Enable and setup tolerance display
(vla-put-ToleranceDisplay dimObj acTolLimits)
(vla-put-ToleranceLowerLimit dimObj -0.0001)
(vla-put-ToleranceUpperLimit dimObj 0.0001)
(vla-ZoomAll acadObj)
;; Toggle the display of zero feet for the dimension tolerance value
(vla-put-ToleranceSuppressZeroFeet dimObj (if (= (vla-get-ToleranceSuppressZeroFeet dimObj) :vlax-true) :vlax-false :vlax-true))
(alert "Suppression of zero feet toggled.")
;; Toggle the display of zero feet for the dimension tolerance value back to previous state
(alert "Suppression of zero feet toggled back.")
GMT+8, 2026-11-2 19:05
