ActiveX 开发指南
相关分类
容差抑制尾随零属性 (ActiveX)
2023-1-3 03:05| 发布者: admin| 查看: 1476| 评论: 0|来自: AutoCAD
摘要: 指定禁止显示维度值中的尾随零。
指定禁止显示维度值中的尾随零。
支持的平台:仅窗口
工 务 局:
object.ToleranceSuppressTrailingZeros
类型:暗三点角度,暗对齐,暗角,暗弧长度,暗直径,尺寸,暗坐标,暗径向,暗径向大,暗心旋转
此属性适用的对象。
只读:不
类型:布尔
  • True:禁止显示十进制值中的尾随零。例如,12.5000 变为 12.5。
  • False:不禁止显示十进制值中的尾随零。
此属性的初始值为。False
注意:此值将覆盖 DIMTZIN 系统变量的值。
工 务 局:
Sub Example_ToleranceSuppressTrailingZeros()
    ' uses ToleranceSuppressTrailingZeros to toggle the display of trailing zeros
    ' in the dimension tolerance display
    Dim dimObj As AcadDimAligned
    ' Define the dimension
    point2(0) = 5.01: point2(1) = 5: point2(2) = 0
    ' Enable and setup tolerance display
    dimObj.ToleranceDisplay = acTolSymmetrical
    dimObj.ToleranceLowerLimit = -0.0001: dimObj.ToleranceUpperLimit = 0.005
Toggle:
    Select Case MsgBox("Press OK to toggle the display of trailing zeros in the dimension tolerance", vbOKCancel)
        Case vbOK
            ' Toggle the display of trailing zeros for the dimension tolerance value
            dimObj.ToleranceSuppressTrailingZeros = Not (dimObj.ToleranceSuppressTrailingZeros)
        Case vbCancel
            Exit Sub
    End Select
    GoTo Toggle
Visual LISP:
(defun c:Example_ToleranceSuppressTrailingZeros()
    ;; uses ToleranceSuppressTrailingZeros to toggle the display of trailing zeros
    ;; in the dimension tolerance display
    ;; Define the dimension
          point2 (vlax-3d-point 5.01 5 0)
    ;; Enable and setup tolerance display
    (vla-put-ToleranceDisplay dimObj acTolSymmetrical)
    (vla-put-ToleranceLowerLimit dimObj -0.0001)
    (vla-put-ToleranceUpperLimit dimObj 0.005)
    (vla-ZoomAll acadObj)
    ;; Toggle the display of trailing zeros for the dimension tolerance value
    (vla-put-ToleranceSuppressTrailingZeros dimObj (if (= (vla-get-ToleranceSuppressTrailingZeros dimObj) :vlax-true) :vlax-false :vlax-true))
    (alert "Suppression of trailing zeros toggled.")
    ;; Toggle the display of trailing zeros for the dimension tolerance value back to previous state
    (alert "Suppression of trailing zeros toggled back.")
GMT+8, 2026-10-27 21:40
