指定文本窗口的背景色。 支持的平台:仅窗口 属性值只读:不 类型:OLE_COLOR(常量)
言论此属性的默认颜色是 Windows 标准窗口颜色。 例子工 务 局: Sub Example_TextWinBackgrndColor()
' TextWinBackgrndColor. It then changes the value, and finally
Dim currTextWinBackgrndColor As OLE_COLOR
Set preferences = ThisDrawing.Application.Preferences
' Retrieve the current TextWinBackgrndColor value
currTextWinBackgrndColor = preferences.Display.TextWinBackgrndColor
MsgBox "The current value for TextWinBackgrndColor is " _
& preferences.Display.TextWinBackgrndColor, vbInformation, "TextWinBackgrndColor Example"
' Change the value for TextWinBackgrndColor
preferences.Display.TextWinBackgrndColor = vbBlue
MsgBox "The new value for TextWinBackgrndColor is " _
' Reset TextWinBackgrndColor to its original value
preferences.Display.TextWinBackgrndColor = currTextWinBackgrndColor
MsgBox "The TextWinBackgrndColor value is reset to " _
Visual LISP: (vl-load-com)
(defun c:Example_TextWinBackgrndColor()
;; TextWinBackgrndColor. It then changes the value, and finally
;; Get the Display preferences object
(setq ACADPref (vla-get-Display preferences))
;; Retrieve the current TextWinBackgrndColor value
(setq currTextWinBackgrndColor (vlax-variant-change-type (vla-get-TextWinBackgrndColor ACADPref) vlax-vbLong))
(alert (strcat "The current value for TextWinBackgrndColor is " (itoa (vlax-variant-value currTextWinBackgrndColor))))
;; Change the value for TextWinBackgrndColor
(vla-put-TextWinBackgrndColor ACADPref (vlax-make-variant acBlue 19))
(setq newValue (vlax-variant-change-type (vla-get-TextWinBackgrndColor ACADPref) vlax-vbLong))
(alert (strcat "The new value for TextWinBackgrndColor is " (itoa (vlax-variant-value newValue))))
;; Reset TextWinBackgrndColor to its original value
(vla-put-TextWinBackgrndColor ACADPref (vlax-variant-change-type currTextWinBackgrndColor 19))
(alert (strcat "The TextWinBackgrndColor value is reset to " (itoa (vlax-variant-value currTextWinBackgrndColor))))
GMT+8, 2026-11-1 16:49
