指定标注文本的旋转角度。 支持的平台:仅窗口 属性值只读:不 类型:双 尺寸文本的角度(以弧度为单位)。有效范围为 0 到 6.28。 言论默认情况下,此值等于 0 度或由标注样式指定的“旋转”属性。 ![]() 0 度角的文本 ![]() 角度等于尺寸旋转的文本 例子工 务 局: Sub Example_TextRotation()
' This example creates an aligned dimension and then changes the
' TextRotation property for that dimension.
Dim dimObj As AcadDimAligned
Dim point1(0 To 2) As Double
Dim point2(0 To 2) As Double
' Define the dimension
point1(0) = 5#: point1(1) = 3#: point1(2) = 0#
point2(0) = 10#: point2(1) = 3#: point2(2) = 0#
location(0) = 7.5: location(1) = 5#: location(2) = 0#
ZoomAll
MsgBox "The current text rotation angle for the dimension is " & dimObj.TextRotation & " radians.", vbInformation, "TextRotation Example"
' Change the text rotation angle to 45 degrees (.707 radians)
dimObj.TextRotation = 0.707
dimObj.Update
MsgBox "The new text rotation angle for the dimension is " & dimObj.TextRotation & " radians.", vbInformation, "TextRotation Example"
Visual LISP: (vl-load-com)
(defun c:Example_TextRotation()
;; This example creates an aligned dimension and then changes the
;; TextRotation property for that dimension.
;; Define the dimension
(setq point1 (vlax-3d-point 5 3 0)
point2 (vlax-3d-point 10 3 0)
location (vlax-3d-point 7.5 5 0))
(vla-ZoomAll acadObj)
(alert (strcat "The current text rotation angle for the dimension is " (rtos (vla-get-TextRotation dimObj) 2) " radians."))
;; Change the text rotation angle to 45 degrees (.707 radians)
(vla-put-TextRotation dimObj 0.707)
(vla-Update dimObj)
(alert (strcat "The new text rotation angle for the dimension is " (rtos (vla-get-TextRotation dimObj) 2) " radians."))
GMT+8, 2026-10-18 18:59
