ActiveX 开发指南
相关分类
TextInsideAlign Property (ActiveX)
2023-1-3 04:02| 发布者: admin| 查看: 1516| 评论: 0|来自: AutoCAD
摘要: 指定除纵坐标之外的所有标注类型的尺寸文本在延伸线内的位置。
支持的平台:仅窗口
工 务 局:
object.TextInsideAlign
类型:暗三点角度,暗对齐,暗角,暗弧长度,暗直径,暗径向,暗径大,暗旋转
此属性适用的对象。
只读:不
类型:布尔
  • True:水平对齐文本。
  • False:将文本与尺寸线对齐。
此属性的初始值为。True
仅当此属性设置为 时,此属性才可用。TextInsideTrue
注意:此属性将覆盖给定维度的 DIMTIH 系统变量的值。
工 务 局:
Sub Example_TextInsideAlign()
    ' allows the user to toggle the TextInsideAlign value for the dimension
    Dim dimObj As AcadDimAligned
    ' Define the dimension
    point2(0) = 5.5: point2(1) = 6: point2(2) = 0
    dimObj.TextInside = True    ' The TextInsideAlign property will only work
                                ' when this property is active
Toggle:
    Select Case MsgBox("Press OK to toggle the TextInsideAlign value for this dimension", vbOKCancel)
        Case vbOK
            ' Toggle the TextInsideAlign value for this dimension
            dimObj.TextInsideAlign = Not (dimObj.TextInsideAlign)
            ' Read and display the new dimension TextInsideAlign value
            MsgBox "TextInsideAlign is currently set to: " & dimObj.TextInsideAlign
        Case vbCancel
            Exit Sub
    End Select
    GoTo Toggle
Visual LISP:
(defun c:Example_TextInsideAlign()
    ;; allows the user to toggle the TextInsideAlign value for the dimension
    ;; Define the dimension
          point2 (vlax-3d-point 5.5 6 0)
    (vla-put-TextInside dimObj :vlax-true)    ;; The TextInsideAlign property will only work
                                              ;; when this property is active
    (vla-ZoomAll acadObj)
    ;; Toggle the TextInsideAlign value for this dimension
    (vla-put-TextInsideAlign dimObj (if (= (vla-get-TextInsideAlign dimObj) :vlax-true) :vlax-false :vlax-true))
    ;; Read and display the new dimension TextInsideAlign value
    (alert (strcat "TextInsideAlign is currently set to: " (if (= (vla-get-TextInsideAlign dimObj) :vlax-true) "True" "False")))
GMT+8, 2026-10-28 16:07
