指定新文本的字体。 支持的平台:仅窗口 属性值只读:不 类型:字符串 新字体的名称。 言论此属性的初始值为“快递”。 例子工 务 局: Sub Example_TextFont()
' TextFont. It then changes the value, and finally
Dim currTextFont As String
Set preferences = ThisDrawing.Application.Preferences
' Retrieve the current TextFont value
currTextFont = preferences.Display.TextFont
MsgBox "The current value for TextFont is " & preferences.Display.TextFont, vbInformation, "TextFont Example"
' Change the value for TextFont
preferences.Display.TextFont = "TestTextFont"
MsgBox "The new value for TextFont is " & preferences.Display.TextFont, vbInformation, "TextFont Example"
' Reset TextFont to its original value
preferences.Display.TextFont = currTextFont
MsgBox "The TextFont value is reset to " & preferences.Display.TextFont, vbInformation, "TextFont Example"
Visual LISP: (vl-load-com)
(defun c:Example_TextFont()
;; TextFont. It then changes the value, and finally
;; Retrieve the current TextFont value
(setq currTextFont (vla-get-TextFont (vla-get-Display preferences)))
(alert (strcat "The current value for TextFont is " currTextFont))
;; Change the value for TextFont
(vla-put-TextFont (vla-get-Display preferences) "TestTextFont")
(alert (strcat "The new value for TextFont is " (vla-get-TextFont (vla-get-Display preferences))))
;; Reset TextFont to its original value
(vla-put-TextFont (vla-get-Display preferences) currTextFont)
(alert (strcat "The TextFont value is reset to " (vla-get-TextFont (vla-get-Display preferences))))
GMT+8, 2026-10-30 07:03
