指定 MTEXT 命令的文本编辑器的名称。 支持的平台:仅窗口 属性值只读:不 类型:字符串 多行文本编辑器的名称。 言论没有额外的评论。 例子工 务 局: Sub Example_TextEditor()
' TextEditor. It then changes the value, and finally
Dim currTextEditor As String
Dim newTextEditor As String
Set preferences = ThisDrawing.Application.preferences
' Retrieve the current TextEditor value
currTextEditor = preferences.Files.TextEditor
MsgBox "The current value for TextEditor is " & currTextEditor, vbInformation, "TextEditor Example"
' Change the value for TextEditor
newTextEditor = "TestTextEditor"
preferences.Files.TextEditor = newTextEditor
MsgBox "The new value for TextEditor is " & newTextEditor, vbInformation, "TextEditor Example"
' Reset TextEditor to its original value
preferences.Files.TextEditor = currTextEditor
MsgBox "The TextEditor value is reset to " & currTextEditor, vbInformation, "TextEditor Example"
Visual LISP: (vl-load-com)
(defun c:Example_TextEditor()
;; TextEditor. It then changes the value, and finally
;; Retrieve the current TextEditor value
(setq currTextEditor (vla-get-TextEditor (vla-get-Files preferences)))
(alert (strcat "The current value for TextEditor is " currTextEditor))
;; Change the value for TextEditor
(setq newTextEditor "TestTextEditor")
(vla-put-TextEditor (vla-get-Files preferences) newTextEditor)
(alert (strcat "The new value for TextEditor is " newTextEditor))
;; Reset TextEditor to its original value
(vla-put-TextEditor (vla-get-Files preferences) currTextEditor)
(alert (strcat "The TextEditor value is reset to " currTextEditor))
GMT+8, 2026-11-2 19:06
