指定禁止显示尺寸值中的前导零。 支持的平台:仅窗口 属性值只读:不 类型:布尔
言论此属性的初始值为。False 注意:此值将覆盖 DIMZIN 系统变量的值。
例子工 务 局: Sub Example_SuppressLeadingZeros()
' uses the SuppressLeadingZeros property to toggle the display of leading zeros
' in the dimension display
Dim dimObj As AcadDimAligned
' Define the dimension
point2(0) = 5.01: point2(1) = 5: point2(2) = 0
Toggle:
Select Case MsgBox("Press OK to toggle the display of leading zeros in the dimension", vbOKCancel)
Case vbOK
' Toggle the display of leading zeros for the dimension value
dimObj.SuppressLeadingZeros = Not (dimObj.SuppressLeadingZeros)
Case vbCancel
Exit Sub
End Select
GoTo Toggle
Visual LISP: (vl-load-com)
(defun c:Example_SuppressLeadingZeros()
;; uses the SuppressLeadingZeros property to toggle the display of leading zeros
;; in the dimension display
;; Define the dimension
point2 (vlax-3d-point 5.01 5 0)
(vla-ZoomAll acadObj)
;; Toggle the display of leading zeros for the dimension value
(vla-put-SuppressLeadingZeros dimObj (if (= (vla-get-SuppressLeadingZeros dimObj) :vlax-true) :vlax-false :vlax-true))
(alert "Suppression of leading zeros toggled.")
;; Toggle the display of leading zeros for the dimension value back to previous state
(alert "Suppression of leading zeros toggled back.")
GMT+8, 2026-10-27 21:08
