获取视区的当前活动状态。 支持的平台:仅窗口 属性值只读:是的 类型:布尔
言论没有额外的评论。 例子工 务 局: Sub Example_StatusID()
' This example displays the setting of StatusID.
Dim currStatusID As Boolean
' Display the current setting of statusID
currStatusID = ThisDrawing.Application.statusID(ThisDrawing.ActiveViewport)
MsgBox "The statusID of the active viewport is: " & currStatusID, , "StatusID Example"
Visual LISP: (vl-load-com)
(defun c:Example_StatusID()
;; This example displays the setting of StatusID.
;; Display the current setting of statusID
(setq currStatusID (vla-get-statusID acadObj (vla-get-ActiveViewport doc)))
(alert (strcat "The statusID of the active viewport is: " (if (= currStatusID :vlax-true) "True" "False")))
GMT+8, 2026-10-27 21:40
