ActiveX 开发指南
相关分类
SolidFill Property (ActiveX)
2023-1-3 05:58| 发布者: admin| 查看: 1637| 评论: 0|来自: AutoCAD
摘要: 指定是否填充迹线、实体、所有填充线(包括实体填充)和宽折线。
支持的平台:仅窗口
工 务 局:
object.SolidFill
类型:数据库首选项
此属性适用的对象。
只读:不
类型:布尔
  • True:显示实心填充。
  • False:不显示实心填充。
此属性的初始值为。True
注意:此属性的值存储在 FILLMODE 系统变量中。
工 务 局:
Sub Example_SolidFill()
    ' This example reads and modifies the preference value that controls
    ' whether multilines, traces, solids, all hatches (including solid-fill)
    ' and wide polylines are filled in.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadDatabasePreferences
    ' Get the user preferences object
    Set ACADPref = ThisDrawing.Preferences
    originalValue = ACADPref.SolidFill
    MsgBox "The SolidFill preference is set to: " & originalValue
    ' Modify the SolidFill preference by toggling the value
    ACADPref.SolidFill = Not (ACADPref.SolidFill)
    newValue = ACADPref.SolidFill
    MsgBox "The SolidFill preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.SolidFill = originalValue
    MsgBox "The SolidFill preference was reset back to: " & originalValue
Visual LISP:
(defun c:Example_SolidFill()
    ;; This example reads and modifies the preference value that controls
    ;; whether multilines, traces, solids, all hatches (including solid-fill)
    ;; and wide polylines are filled in.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    (setq preferences (vla-get-Preferences doc))
    (setq originalValue (vla-get-SolidFill preferences))
    (alert (strcat "The SolidFill preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
    ;; Modify the SolidFill preference by toggling the value
    (vla-put-SolidFill preferences (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (setq newValue (vla-get-SolidFill preferences))
    (alert (strcat "The SolidFill preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
    ;;         this preference in effect
    (vla-put-SolidFill preferences originalValue)
    (alert (strcat "The SolidFill preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-10-27 21:08
