获取文档的选择集集合。 支持的平台:仅窗口 言论没有额外的评论。 例子工 务 局: Sub Example_SelectionSets()
' This example finds the current SelectionSets collection and
' adds a new SelectionSet to that collection.
Dim SSetColl As AcadSelectionSets
Set SSetColl = ThisDrawing.SelectionSets
' Create a SelectionSet named "TEST" in the current drawing
Set ssetObj = SSetColl.Add("TEST")
MsgBox "A new SelectionSet called " & ssetObj.name & " has been added to the SelectionSets collection.", vbInformation, "SelectionSets Example"
Visual LISP: (vl-load-com)
(defun c:Example_SelectionSets()
;; This example finds the current SelectionSets collection and
;; adds a new SelectionSet to that collection.
(setq SSetColl (vla-get-SelectionSets doc))
;; Create a SelectionSet named "TEST" in the current drawing
(setq ssetObj (vla-Add SSetColl "TEST"))
(alert (strcat "A new SelectionSet called " (vla-get-Name ssetObj) " has been added to the SelectionSets collection."))
(vla-Delete ssetObj)
GMT+8, 2026-10-29 21:02
