获取首选项选择对象。 支持的平台:仅窗口 言论该对象保存存储在注册表中的“选项”对话框中“选择”选项卡中的所有选项。与图形一起存储的所有选项都可以在对象上找到。PreferencesSelectionDatabasePreferences 例子工 务 局: Sub Example_Selection()
' This example obtains a reference to the Selection Preferences object
' from the Application Preferences object, and reads one of the Selection
' preferences
Dim ACADPref As AcadPreferencesSelection
' Obtain a reference to the Selection Preferences object
Set ACADPref = ThisDrawing.Application.Preferences.Selection
MsgBox "We now have access to the properties and methods of the Selection Preferences object!"
MsgBox "The Selection preference GripSize is set to: " & ACADPref.GripSize
Visual LISP: (vl-load-com)
(defun c:Example_Selection()
;; This example obtains a reference to the Selection Preferences object
;; from the Application Preferences object, and reads one of the Selection
;; preferences
(alert "We now have access to the properties and methods of the Selection Preferences object!")
(alert (strcat "The Selection preference GripSize is set to: " (itoa (vla-get-GripSize (vla-get-Selection preferences)))))
GMT+8, 2026-10-28 04:48
