ActiveX 开发指南
相关分类
第二点属性 (ActiveX)
2023-1-3 06:50| 发布者: admin| 查看: 1573| 评论: 0|来自: AutoCAD
摘要: 指定射线或 xline 的第二个点。
指定射线或 xline 的第二个点。
支持的平台:仅窗口
工 务 局:
object.SecondPoint
类型:射线,射线
此属性适用的对象。
只读:不
类型:变体(双精度的三元素数组)
表示射线或 xline 的第二个点的 3D WCS 坐标。
不能将射线的第二个点设置为等于其基点。
工 务 局:
Sub Example_SecondPoint()
    ' This example creates a ray object. It then finds the
    ' second point of the ray, changes the second point, and
    ' queries the new second point.
    Dim basePoint(0 To 2) As Double
    Dim directionVec(0 To 2) As Double
    Dim rayObj As AcadRay
    Dim currSecondPoint As Variant
    Dim msg As String
    Dim newSecondPoint(0 To 2) As Double
    ' Establish the base point and directional vector for the ray
    basePoint(0) = 3: basePoint(1) = 3: basePoint(2) = 0
    directionVec(0) = 1:    directionVec(1) = 1: directionVec(2) = 0
    ' Create a Ray object in model space
    Set rayObj = ThisDrawing.ModelSpace.AddRay(basePoint, directionVec)
    ThisDrawing.Regen True
    MsgBox "A new Ray has been added.", vbInformation
    ' Define a new second point
    newSecondPoint(0) = 4: newSecondPoint(1) = 2: newSecondPoint(2) = 0
    ' Update the ray using the new second point
    rayObj.SecondPoint = newSecondPoint
    ' Query the new second point for the Ray
    currSecondPoint = rayObj.SecondPoint
    msg = currSecondPoint(0) & vbCrLf & _
          currSecondPoint(1) & vbCrLf & _
          currSecondPoint(2)
    MsgBox "We've just changed the second point of the new Ray to: " & vbCrLf & msg, vbInformation
Visual LISP:
(defun c:Example_SecondPoint()
    ;; This example creates a ray object. It then finds the
    ;; second point of the ray, changes the second point, and
    ;; queries the new second point.
    ;; Establish the base point and directional vector for the ray
    (setq basePoint (vlax-3d-point 3 3 0)
          directionVec (vlax-3d-point 1 1 0))
    ;; Create a Ray object in model space
    (setq rayObj (vla-AddRay modelSpace basePoint directionVec))
    (vla-Regen doc :vlax-true)
    (alert "A new Ray has been added.")
    ;; Define a new second point
    (setq newSecondPoint (vlax-3d-point 4 2 0))
    ;; Update the ray using the new second point
    (vla-put-SecondPoint rayObj newSecondPoint)
    ;; Query the new second point for the Ray
    (setq currSecondPoint (vlax-safearray->list (vlax-variant-value (vla-get-SecondPoint rayObj))))
    (setq msg (strcat (rtos (nth 0 currSecondPoint) 2) ", "
		      (rtos (nth 1 currSecondPoint) 2) ", "
		      (rtos (nth 2 currSecondPoint) 2)))
    (alert (strcat "We've just changed the second point of the new Ray to: " msg))
GMT+8, 2026-10-27 05:40
