控制时间敏感的右键单击行为。 支持的平台:仅窗口 属性值只读:不 类型:布尔
言论此属性用于设置时间敏感的右键单击行为。快速单击与按 Enter 相同。单击时间越长,将显示快捷菜单。仅当属性设置为时,才能设置此属性。ShortcutMenuDisplayTrue 您可以使用属性设置右键单击的持续时间。SCMTimeValue 注意:此属性的值存储在 SHORTCUTMENUDURATION 系统变量中。
例子工 务 局: Sub Example_SCMTimeMode()
' This example reads and modifies the SCMTimeMode property.
' Then the property is reset to its original value.
Dim ACADPref As AcadPreferencesUser
Dim originalValue As Boolean, newValue As Boolean
' Get the UserPreferences object
Set ACADPref = ThisDrawing.Application.Preferences.User
originalValue = ACADPref.SCMTimeMode
MsgBox "The SCMTimeMode property is currently: " & originalValue
newValue = IIf(originalValue, False, True)
ACADPref.SCMTimeMode = newValue
MsgBox "The SCMTimeMode property has been set to: " & ACADPref.SCMTimeMode
ACADPref.SCMTimeMode = originalValue
MsgBox "The SCMTimeMode property was reset back to: " & originalValue
Visual LISP: (vl-load-com)
(defun c:Example_SCMTimeMode()
;; This example reads and modifies the SCMTimeMode property.
;; Then the property is reset to its original value.
(setq originalValue (vla-get-SCMTimeMode (vla-get-User preferences)))
(alert (strcat "The SCMTimeMode property is currently: " (if (= originalValue :vlax-true) "True" "False")))
;; Modify the SCMTimeMode preference by toggling the value
(setq newValue (if (= originalValue :vlax-true) :vlax-false :vlax-true))
(vla-put-SCMTimeMode (vla-get-User preferences) newValue)
(alert (strcat "The SCMTimeMode property has been set to: " (if (= newValue :vlax-true) "True" "False")))
(vla-put-SCMTimeMode (vla-get-User preferences) originalValue)
(alert (strcat "The SCMTimeMode property was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-10-29 12:30
