ActiveX 开发指南
相关分类
RemoveHiddenLines Property (ActiveX)
2023-1-3 07:30| 发布者: admin| 查看: 1709| 评论: 0|来自: AutoCAD
摘要: 指定是否要在图纸空间视口上绘制隐藏线。(已过时)
支持的平台:仅窗口
工 务 局:
object.RemoveHiddenLines
类型:光伏港
此属性适用的对象。
只读:不
类型:布尔
  • True:删除绘图中的隐藏线。
  • False:不删除绘图中的隐藏线。
此属性已过时,将在将来的版本中删除。
工 务 局:
Sub Example_RemoveHiddenLines()
    ' This example creates a new paper space viewport.
    ' It then displays the value of RemoveHiddenLines for the viewport.
    Dim pviewportObj As AcadPViewport
    Dim center(0 To 2) As Double
    Dim width As Double
    Dim height As Double
    ' Define the paper space viewport
    center(0) = 3: center(1) = 3: center(2) = 0
    width = 40
    height = 40
    ' Change from model space to paper space
    ThisDrawing.ActiveSpace = acPaperSpace
    ' Create the paper space viewport
    Set pviewportObj = ThisDrawing.PaperSpace.AddPViewport(center, width, height)
    pviewportObj.DISPLAY True
    ThisDrawing.mspace = True
    ThisDrawing.ActivePViewport = pviewportObj
    ' Find the value for RemoveHiddenLines for the viewport
    Dim removeHidden As Boolean
    removeHidden = pviewportObj.RemoveHiddenLines
    MsgBox "The value of the RemoveHiddenLines property for the paperspace viewport is " & pviewportObj.RemoveHiddenLines, , "RemoveHiddenLines Example"
Visual LISP:
(defun c:Example_RemoveHiddenLines()
    ;; This example creates a new paper space viewport.
    ;; It then displays the value of ShadePlot for the viewport.
    ;; ShadePlot replaces RemoveHiddenLines.
    ;; Define the paper space viewport
    (setq center (vlax-3d-point 3 3 0)
          width 40
          height 40)
    ;; Change from model space to paper space
    (vla-put-ActiveSpace doc acPaperSpace)
    ;; Create the paper space viewport
    (setq paperSpace (vla-get-PaperSpace doc))
    (setq pviewportObj (vla-AddPViewport paperSpace center width height))
    (vla-Display pviewportObj :vlax-true)
    (vla-put-MSpace doc :vlax-true)
    (vla-put-ActivePViewport doc pviewportObj)
    ;; Find the value for ShadePlot for the viewport
    (alert (strcat "The value of the ShadePlot property for the paperspace viewport is " (itoa (vla-get-ShadePlot pviewportObj))))
GMT+8, 2026-11-29 10:37
