指定文档或属性是只读还是读写。 支持的平台:仅窗口 属性值只读:是的 类型:布尔
言论没有额外的评论。 例子工 务 局: Sub Example_ReadOnly()
' This example shows if current drawing file is read only or not
If ThisDrawing.ReadOnly Then
MsgBox "The current drawing file is read only.", , "ReadOnly Example"
Else
MsgBox "The current drawing file is read-write.", , "ReadOnly Example"
End If
Visual LISP: (vl-load-com)
(defun c:Example_ReadOnly()
;; This example shows if current drawing file is read only or not
(if (= (vla-get-ReadOnly doc) :vlax-true)
(alert "The current drawing file is read only.")
(alert "The current drawing file is read-write.")
GMT+8, 2026-11-10 11:00
