查看: 816|回复: 0
U4GM: Diablo 4 Season 13 Frenzy Barbarian Build Guide
发表于 2026-6-13 11:07:44 | 显示全部楼层 |阅读模式
Season 13 of Diablo 4 - Lord of Hatred gives Barbarian players a good reason to revisit a classic idea: the dual-wield Frenzy Berserker. It's fast, aggressive, and built around constant hits that slowly turn into a blur of damage Diablo 4 gold.
Instead of relying on big cooldown nukes, this build wins by stacking attack speed, keeping buffs active, and staying glued to enemies until they fall over. If you like melee builds that feel nonstop and hands-on, Frenzy is one of the most satisfying Barbarian playstyles right now.
Why Frenzy Works in Season 13
Frenzy is a Basic Skill that ramps up attack speed the longer you keep hitting. Season 13 systems make that style stronger than before, especially with better scaling from gear, tempering, and passive bonuses.
In practice, a Frenzy Barbarian gives you:
Strong single-target damage for bosses and elites
Very consistent performance in high-tier content
Easy scaling from leveling into endgame
High uptime on buffs like Berserking and Fortify
It's not the flashiest build, but it's reliable-and once it gets going, it feels almost unstoppable in close range.
Core Skill Setup
The build revolves around staying in melee range and never stopping your attack chain.
1. Frenzy (Main Skill)
This is your core damage source. You want as many ranks as possible from gear and tempering. Once fully stacked, Frenzy becomes a rapid multi-hit engine that constantly triggers effects.
2. Shouts + Berserking
Most setups run:
Rallying Cry - Fury generation and mobility
War Cry - damage boost
Challenging Shout - survivability in dense fights
Later on, Wrath of the Berserker becomes your main burst cooldown, used for elites, bosses, and heavy pulls.
3. Control Skills
Ground Stomp - groups enemies and stuns
Steel Grasp - pulls targets into melee range
These help keep fights tight so you can maintain Frenzy uptime without chasing enemies.
Weapons and Arsenal Choices
Since Frenzy is dual-wield focused, weapon quality matters a lot.
Most endgame setups combine:
Fast one-handed weapons for Frenzy stacks
A strong two-handed weapon for Arsenal bonuses
Popular choices vary between swords for speed or maces for heavier hits, depending on your stat balance.
For Technique, players often pick either:
Polearm for crit-focused setups
Two-handed axe for damage vs Vulnerable targets
Tempering is where a lot of damage comes from now, especially when you hit good Frenzy or basic skill rolls.
Aspects, Uniques, and Gear
Frenzy Barb scales best with attack speed and “on-hit” effects.
You're generally looking for:
Damage while Berserking
Damage vs Crowd Controlled or Vulnerable enemies
Attack speed bonuses
Resource sustain effects
Some high-end builds include uniques like Ring of Starless Skies, but Frenzy doesn't require perfect gear to function well.
Defensively, anything that boosts:
Damage reduction
Fortify generation
Barriers or healing
will make a big difference, since you're always fighting in melee range.
Tempering and Paragon Focus
A lot of Frenzy's power in Season 13 comes from optimization rather than raw weapon DPS.
1. Tempering priorities:
Frenzy ranks
Basic skill damage
Crit damage or attack speed
Barbarian passives that support Fury or Berserking
Paragon boards:
Most builds start with general Barbarian damage and defense boards, then move into Berserking or weapon-focused setups.
2. Key glyphs:
Exploit
Wrath
Territorial
Imbiber
Melee damage-focused glyphs
Leveling glyphs to 15 and eventually 21 is a major power spike over time.
How the Build Plays
Frenzy gameplay is very straightforward, but timing matters.
1. Pull enemies together with Ground Stomp or Steel Grasp
2. Start stacking Frenzy on priority targets
3. Rotate Shouts to maintain buffs
4. Use Wrath of the Berserker for elites and bosses
Against bosses, the loop is simple: stay close, dodge big hits, and never stop attacking long enough to lose momentum.
Once it clicks, the build feels like a constant rhythm of buffs, hits, and repositioning.
Leveling Into Frenzy
Frenzy is playable early, but it feels much better once you have core gear and tempering unlocked.
Most players level with Whirlwind or a slam build first, then respec into Frenzy once they have:
Attack speed gear
Basic skill scaling
At least one strong weapon setup
If you do want to start Frenzy early, just lean heavily on Shouts and mobility skills to keep fights smooth.
Final Thoughts
The Frenzy Barbarian isn't about big flashy explosions-it's about pressure.
Once the build comes online, you're constantly hitting, constantly moving, and constantly stacking buffs until enemies stop existing. It's simple, but extremely satisfying when everything is tuned correctly.
If Season 13 has you looking for a melee build that feels fast, aggressive, and always active, Frenzy Barbarian is one of the best ways to play Barbarian right now.
As a trusted gaming service platform, U4GM.com helps players stay up to date with Diablo 4 guides, builds, and in-game details. You can also find exclusive offers on cheap Diablo 4 gold.
本帖子中包含更多资源
您需要 登录 才可以下载或查看,没有帐号?立即注册
x
