查看: 105|回复: 0
D2R Conversion Deadline Guide for U4gm Players
发表于 2026-11-14 10:35:30 | 显示全部楼层 |阅读模式
D2R players have a short window to decide which online Lord of Destruction characters should enter Reign of the Warlock. The Patch 3.4 notes say that online Expansion conversions stop on November 16, so check the characters holding your D2R Ladder Items before making a move. The cutoff applies to both Ladder and Non-Ladder characters.
Which D2R characters are affected by the November 16 deadline
The deadline covers online characters in the Lord of Destruction Expansion partition. It affects both current Ladder characters and Non-Ladder characters, including mules you may not have played for months. If one of them needs to enter Reign of the Warlock, make that decision before November 16.
Offline conversions remain available after the cutoff. Classic characters can also still convert to Lord of Destruction, although that does not mean the online Expansion-to-Warlock route will remain open for them. Check where each character currently sits before deciding what needs attention.
The notes describe a cutoff for further conversions, not the removal of characters already in Reign of the Warlock. Your immediate concern is the online Expansion character still waiting at the selection screen, along with the gear you want that character to carry across.
What should you do before converting a D2R character
Start by checking every online Expansion character you care about, including storage mules. Decide which ones you actually want to play in Reign of the Warlock and which ones hold equipment you want there. A mule can matter just as much as your main if it is carrying the charms, jewels, or spare gear you planned to use.
Before converting, take off anything you want to keep in Lord of Destruction. The character and the items it carries move together, so a quick inventory check can save you from leaving a favorite setup on the wrong side. Give shared stash tabs a careful look too, but do not assume the notes describe a general stash wipe.
Once you have made the move, log in and check the character, inventory, and stash tabs before settling into a long session. That gives you a chance to spot an item you meant to move while your original plan is still fresh. Finish any active run first, then leave yourself time to review the result.
Does Ladder Season 16 change the conversion deadline
Season 16 began on November 13 in North America and November 14 in Europe and Asia. Those regional start times explain when players could begin the new ladder; they do not extend the November 16 conversion cutoff. Starting a fresh ladder character and converting an existing Expansion character are separate decisions.
Patch 3.4 also changes the availability of some items and updates certain uniques, Isenhart's Armory, and the Eternity runeword under specified play conditions. None of those changes keeps online Expansion conversions open longer. Do not wait for a planned upgrade if the character holding the gear still needs to move.
Finally, review your online Lord of Destruction roster, decide where each character and its gear belongs, and complete any planned conversions before November 16. Afterward, check your characters and Diablo 2 Resurrected Items in Reign of the Warlock, then get back to your Season 16 runs with the decision settled.
