查看: 102|回复: 0
U4gm Explains Pick Dodger in NBA 2K27
发表于 2026-11-13 11:46:06 | 显示全部楼层 |阅读模式
A good screen can turn a steady defensive possession into a scramble in NBA 2K27. Pick Dodger helps your defender work around that screen and stay closer to the ball handler, making it a useful badge for guards who face pick-and-rolls. If you use NBA 2K27 MT to build your lineup, think about who you trust to defend the ball as well as who can score.
What Does Pick Dodger Do in NBA 2K27
Pick Dodger improves a defender's ability to get around offensive screens. Its value shows up when a ball handler uses a teammate's position to create separation, forcing you to follow through traffic instead of running straight at your matchup.
For a guard, that can mean staying close enough to keep pressure on the ball after the screen. Without that proximity, the offense has more room to attack while your defense tries to recover.
The badge is most useful when screens are a regular part of the possession. A guard who spends much of the game defending the ball has more chances to put it to work than a player who rarely has to chase through a pick.
How Do You Use Pick Dodger Against a Pick-and-Roll
Start by watching the screener as well as the ball handler. When the screen is coming, move with a purpose: your goal is to stay connected to the dribbler while finding a path around the teammate setting the pick.
Don't treat Pick Dodger as a reason to run straight into every screen. It improves your ability to get around screens, but your positioning still matters. If you react late or take a poor angle, you can leave your teammates dealing with the space behind you.
Pay attention to what happens after you clear the screen. Getting back near the ball handler is only part of the possession; you still need to stay in front and be ready for the next move. A rushed recovery can give the attacker room to change direction.
The pick-and-roll also asks the rest of your defense to make decisions. Staying attached to the ball can reduce the pressure on teammates who would otherwise have to cover for a defender stuck behind the screen.
Is Pick Dodger Worth Using for Guards
Pick Dodger makes the most sense on a guard you regularly use against opposing ball handlers. If you often find yourself caught behind the screener, the badge addresses a problem you'll recognize immediately during games.
Its value depends on your role, though. A guard who spends possessions away from the ball may get fewer chances to benefit, so consider how you actually defend before making it a priority in your lineup decisions.
Judge it over several possessions rather than a single play. Look at how often your defender stays close after a screen and how much recovery work the rest of your team has to do. That gives you a clearer idea of its value for your style.
Pick Dodger gives ball defenders help against one of basketball's most common actions, but you'll still need to read the screen and move into a useful position. Next, try your guard against repeated pick-and-rolls and see where you lose contact; additionally, if you plan to buy 2K27 MT for your lineup, keep that defensive role in mind as you choose players.
