查看: 51|回复: 0
MLB The Show 26 Strategy Tips from U4GM
发表于 2026-9-14 11:01:47 | 显示全部楼层 |阅读模式
Most online PCA write-ups show the perfect homer or a clean stolen base, then skip the less exciting part: turning a fast center fielder into reliable offense across ordinary at-bats. In MLB The Show 26, Pete Crow-Armstrong's rise to a 94 rating makes him worth another look, but buying MLB 26 stubs for a card is only sensible if he solves a real lineup need. PCA is not at his best when treated like a pure power bat. He earns his spot by forcing rushed decisions, taking extra bases, and covering enough ground in center to free up other roster choices.
Build At-Bats Around Pressure, Not Just Power
The mistake with PCA is sitting on one pitch and trying to repeat his recent home-run stretch every plate appearance. His speed makes any solid ball in play more valuable than it would be for a slower hitter.
◆ Hunt for pitches you can drive into the gaps rather than trying to pull every hittable ball.
◆ Take the easy single when the infield is positioned deep or shifted toward a power threat.
◆ Make fielders execute cleanly after putting the ball on the ground with two strikes.
That approach matters because PCA can turn a routine-looking hit into an immediate scoring situation. A base hit followed by a strong lead changes the next pitcher's attention. Even when he does not steal, the defense may shade middle infielders, call more cautious pitches, or rush a throw on a ball in play.
Pair Him With a Hitter Who Punishes Caution
PCA has greater value when the hitter directly after him presents a different problem. Put a genuine extra-base threat behind him, especially one you trust to handle runners in scoring position. The opponent then has to choose between attacking PCA early or working around him and facing the next hitter with traffic on the bases.
◆ Use PCA ahead of a hitter who can drive mistakes, not another player dependent on steals.
◆ Avoid stacking too many similar contact-and-speed cards in the same pocket of the order.
◆ Let the matchup decide whether he belongs first, second, or in the lower middle of the lineup.
Near the top, he can influence more innings with his defense and running. Lower in the order, he works well as a secondary creator who gets on base before the lineup turns over. The better choice depends on whether your existing top hitters already provide consistent contact.
Read the Pitcher Before Taking the Extra Base
Speed is useful only when it is applied with discipline. Automatically running with PCA gives away outs and lets the opponent settle into predictable defensive calls. Spend the first time on base watching delivery speed, pickoff habits, and whether the pitcher repeatedly checks the runner.
◆ Take a larger lead only after a slow, repeatable delivery gives you a reason.
◆ Stay conservative against quick motions and frequent pickoff attempts.
◆ Use the threat of movement to create better pitches for the hitter at the plate.
The goal is not to force a steal every time. The goal is to make the pitcher split attention. That small hesitation can produce the fastball or hanging breaking ball your next hitter needs.
Let His Defense Shape the Rest of the Outfield
PCA's center-field range is a roster advantage, particularly if your corners are chosen mainly for offense. With reliable coverage in the middle, you can be less concerned about asking a corner outfielder to cover too much space. That flexibility matters during close games, where one ball in the gap can erase several productive innings.
His card also remains useful during a cold hitting stretch because defense and speed do not disappear when timing feels off. A pure slugger who is not squaring up can become a passenger; PCA can still save runs and create pressure after reaching on a walk or single.
Use PCA in MLB The Show 26 when your roster needs speed, center-field coverage, and a hitter who creates uncomfortable innings rather than only chasing home runs. If you are considering MLB The Show 26 Stubs, judge him against the role he fills beside your power hitters, not against a highlight reel from a 99-rated slugger.
GMT+8, 2026-9-25 22:18
