查看: 278|回复: 0
POE 3.29 Heist Progression: U4GM's Vox Twins Guide
发表于 2026-8-31 17:02:22 | 显示全部楼层 |阅读模式
Three map sessions, a pile of Smuggler's Caches, and still no Contract: The Twins. That is the POE 3.29 experience that sends players searching for Vox Twins guides while their stash fills with POE currency and unrelated Heist loot. The encounter feels like a broken quest, but the real problem is usually a mix of scripted story timing, rare contract availability, and poor quest order. Treat those as separate systems and the path becomes much easier to read.
First, Fix The Rescue
The Rescue is not a contract you should speedrun on autopilot. Rescue Hana, reach the Vox area, and stay put while the dialogue finishes and the alarm sequence begins. Leaving the zone immediately after the rescue objective appears can leave the story stage in an awkward state. Once the escape is complete, return to Kurai in Rogue Harbour and check for new dialogue before you start farming maps.
That check matters because Contract: The Twins is not the same type of item as a normal green quest contract. It is a rare unique contract linked to Smuggler's Caches, so the next cache is not guaranteed to contain it. From what I've seen, players waste more time assuming they missed a scripted drop than they would spend checking Kurai, their Heist storage, and the quest log in the right order.
The Search Plan That Actually Saves Time
Run maps you already want to clear instead of forcing a low-value Heist loop. Keep cache chance active through your Atlas setup, open every Smuggler's Cache you encounter, and let the Vox search run alongside Atlas completion, red-map objectives, and other league challenges. RNG can be rough here, but every map should still produce progress somewhere.
Finish The Rescue and wait for the alarm before leaving.
Speak with Kurai before completing the unique contract.
Check Heist storage after every longer mapping session.
Keep suitable contracts and blueprints rather than discarding them.
Record the area level before entering The Twins.
Quest Order Versus Contract Availability
There are two different failure-looking situations in POE 3.29. The first is normal rarity: the quest is ready, but the contract simply has not appeared. The second involves completing the unique contract before the earlier Kurai stage is properly turned in, which can interfere with expected dialogue or reward handling. The safest sequence is simple: complete The Rescue, speak with Kurai, then run The Twins when it arrives.
Situation        Best response
No contract after several maps        Keep opening Smuggler's Caches while pursuing other goals
Kurai has no expected dialogue        Recheck The Rescue completion and contract order
Contract completed but challenge failed        Check the area level before another attempt
Contract missing from normal stash        Look in the Heist storage interface
Making The Twins Count for Challenging Curators
The Vox Twins are one option for 21: Challenging Curators, which asks for six eligible encounters at level 80 or higher. Defeating the pair is not enough if the contract area is too low level, so inspect the contract before launching it. That small check prevents a frustrating clear that gives loot but no challenge progress. You can also use alternatives such as Izaro, an Abyssal Lich, the Omnitect, a Beyond boss, an Expedition boss, or listed Kingsmarch encounters.
My Practical Verdict
I could be wrong but, for most POE 3.29 players, Vox Twins should be treated as a bonus target rather than the single gate for a 36-challenge reward plan. Finish the story cleanly, keep mapping, and don't burn your entire session staring at cache drops. In a trade league, another player may have Contract: The Twins available; in a self-found setup, patience and efficient map routing are your only realistic tools. Spend your spare time on maps, Heist supplies, and POE currency trade options, then return to the encounter when the contract finally shows up.
GMT+8, 2026-11-8 05:54
