切换打印错误报告的静默错误模式。 支持的平台:仅窗口 属性值只读:不 类型:布尔
言论安静错误模式将所有与绘图相关的错误消息记录到日志文件中。 禁用安静错误模式时,将使用正常的错误报告机制(警报框)。 例子工 务 局: Sub Example_QuietErrorMode() ' This example plots the layouts of a drawing. Dim oPlot As AcadPlot Dim AddedLayouts() As String Dim LayoutList As Variant Dim oLayout As ACADLayout Dim ArraySize As Integer, BatchCount As Integer For Each oLayout In ThisDrawing.Layouts ArraySize = ArraySize + 1 ReDim Preserve AddedLayouts(1 To ArraySize) AddedLayouts(ArraySize) = oLayout.Name Next LayoutList = AddedLayouts Set oPlot = ThisDrawing.Plot oPlot.SetLayoutsToPlot LayoutList oPlot.PlotToDevice "DWF6 ePlot.pc3" End Sub Visual LISP: (vl-load-com) (defun c:Example_QuietErrorMode() ;; This example plots the layouts of a drawing. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (setq AddedLayouts (vlax-make-safearray vlax-vbString (cons 0 (1- (vla-get-Count (vla-get-Layouts doc))))) ArraySize 0) (vlax-for oLayout (vla-get-Layouts doc) (vlax-safearray-put-element AddedLayouts ArraySize (vla-get-Name oLayout)) (setq ArraySize (1+ ArraySize)) ) (setq oPlot (vla-get-Plot doc)) (setq currMode (vla-get-QuietErrorMode oPlot)) (vla-put-QuietErrorMode oPlot :vlax-true) (vla-SetLayoutsToPlot oPlot AddedLayouts) (vla-PlotToDevice oPlot "DWF6 ePlot.pc3") (vla-put-QuietErrorMode oPlot currMode) ) |
GMT+8, 2024-6-10 19:46
