控制在第三方应用程序中创建的图形中对象的显示。 支持的平台:仅窗口 属性值只读:不 类型:枚举acProxyImage
言论此属性的初始值为。acProxyShow 例子工 务 局: Sub Example_ProxyImage() ' This example returns the current setting of ' ProxyImage. It then changes the value, and finally ' it resets the value back to the original setting. Dim preferences As AcadPreferences Dim currProxyImage As Integer Dim constant As String Dim newConstant As String Set preferences = ThisDrawing.Application.preferences ' Retrieve the current ProxyImage value currProxyImage = preferences.OpenSave.ProxyImage constant = Choose(currProxyImage + 1, "acProxyNotShow", "acProxyShow", "acProxyBoundingBox") MsgBox "The current value for ProxyImage is " & constant, vbInformation, "ProxyImage Example" ' Change the value for ProxyImage newConstant = "acProxyBoundingBox" preferences.OpenSave.ProxyImage = acProxyBoundingBox MsgBox "The new value for ProxyImage is " & newConstant, vbInformation, "ProxyImage Example" ' Reset ProxyImage to its original value preferences.OpenSave.ProxyImage = currProxyImage MsgBox "The ProxyImage value is reset to " & constant, vbInformation, "ProxyImage Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_ProxyImage() ;; This example returns the current setting of ;; ProxyImage. It then changes the value, and finally ;; it resets the value back to the original setting. (setq acadObj (vlax-get-acad-object)) (setq preferences (vla-get-Preferences acadObj)) ;; Retrieve the current ProxyImage value (setq currProxyImage (vla-get-ProxyImage (vla-get-OpenSave preferences))) (setq constant (cond ((= currProxyImage 0) "acProxyNotShow") ((= currProxyImage 1) "acProxyShow") ((= currProxyImage 2) "acProxyBoundingBox") )) (alert (strcat "The current value for ProxyImage is " constant)) ;; Change the value for ProxyImage (setq newConstant "acProxyBoundingBox") (vla-put-ProxyImage (vla-get-OpenSave preferences) acProxyBoundingBox) (alert (strcat "The new value for ProxyImage is " newConstant)) ;; Reset ProxyImage to its original value (vla-put-ProxyImage (vla-get-OpenSave preferences) currProxyImage) (alert (strcat "The ProxyImage value is reset to " constant)) ) |
GMT+8, 2024-6-10 15:47
