指定打印机样式表文件的位置。 支持的平台:仅窗口 属性值只读:不 类型:字符串 打印机样式表文件的驱动器和路径。 言论使用分号 (;)分隔多个目录;但是,不要以分号结尾字符串。 例子工 务 局: Sub Example_PrinterStyleSheetPath() ' This example reads and modifies the preference value that controls ' the location for printer style sheet files. ' When finished, this example resets the preference value back to ' its original value. Dim ACADPref As AcadPreferencesFiles Dim originalValue As Variant, newValue As Variant ' Get the files preferences object Set ACADPref = ThisDrawing.Application.Preferences.Files ' Read and display the original value originalValue = ACADPref.PrinterStyleSheetPath MsgBox "The PrinterStyleSheetPath preference is set to: " & originalValue ' Modify the PrinterStyleSheetPath preference by changing the path to "C:\" ACADPref.PrinterStyleSheetPath = "C:\" newValue = ACADPref.PrinterStyleSheetPath MsgBox "The PrinterStyleSheetPath preference has been set to: " & newValue ' Reset the preference back to its original value ' ' * Note: Comment out this last section to leave the change to ' this preference in effect ACADPref.PrinterStyleSheetPath = originalValue MsgBox "The PrinterStyleSheetPath preference was reset back to: " & originalValue End Sub Visual LISP: (vl-load-com) (defun c:Example_PrinterStyleSheetPath() ;; This example reads and modifies the preference value that controls ;; the location for printer style sheet files. ;; When finished, this example resets the preference value back to ;; its original value. (setq acadObj (vlax-get-acad-object)) (setq preferences (vla-get-Preferences acadObj)) ;; Read and display the original value (setq originalValue (vla-get-PrinterStyleSheetPath (vla-get-Files preferences))) (alert (strcat "The PrinterStyleSheetPath preference is set to: " originalValue)) ;; Modify the PrinterStyleSheetPath preference by changing the path to "C:\\" (vla-put-PrinterStyleSheetPath (vla-get-Files preferences) "C:\\") (setq newValue (vla-get-PrinterStyleSheetPath (vla-get-Files preferences))) (alert (strcat "The PrinterStyleSheetPath preference has been set to: " newValue)) ;; Reset the preference back to its original value ;; ;; * Note: Comment out this last section to leave the change to ;; this preference in effect (vla-put-PrinterStyleSheetPath (vla-get-Files preferences) originalValue) (alert (strcat "The PrinterStyleSheetPath preference was reset back to: " originalValue)) ) |
GMT+8, 2024-6-10 19:27
