指定 acad.psf 文件中自定义 prolog 部分的名称。 支持的平台:仅窗口 属性值只读:不 类型:字符串 执行 PSOUT 时要使用的acad.psf文件的后记 prolog 部分的名称。 言论prolog 部分与 PSOUT AutoCAD 命令一起使用,以自定义生成的输出。有关详细信息,请参见 AutoCAD 文档。 注意:此属性的值存储在 PSPROLOG 系统变量中。
例子工 务 局: Sub Example_PostScriptPrologFile() ' This example returns the current setting of ' PostScriptPrologFile. It then changes the value, and finally ' it resets the value back to the original setting. Dim preferences As AcadPreferences Dim currPostScriptPrologFile As String Dim newPostScriptPrologFile As String Set preferences = ThisDrawing.Application.Preferences ' Retrieve the current PostScriptPrologFile value currPostScriptPrologFile = preferences.Files.PostScriptPrologFile If currPostScriptPrologFile = "" Then MsgBox "PostScriptPrologFile is not currently set.", vbInformation, "PostScriptPrologFile Example" Else MsgBox "The current value for PostScriptPrologFile is " & currPostScriptPrologFile, vbInformation, "PostScriptPrologFile Example" End If ' Change the value for PostScriptPrologFile newPostScriptPrologFile = "TestPostScriptPrologFile" preferences.Files.PostScriptPrologFile = newPostScriptPrologFile MsgBox "The new value for PostScriptPrologFile is " & newPostScriptPrologFile, vbInformation, "PostScriptPrologFile Example" ' Reset PostScriptPrologFile to its original value preferences.Files.PostScriptPrologFile = currPostScriptPrologFile If currPostScriptPrologFile = "" Then MsgBox "PostScriptPrologFile is reset to NULL.", vbInformation, "PostScriptPrologFile Example" Else MsgBox "The PostScriptPrologFile value is reset to " & currPostScriptPrologFile, vbInformation, "PostScriptPrologFile Example" End If End Sub Visual LISP: (vl-load-com) (defun c:Example_PostScriptPrologFile() ;; This example returns the current setting of ;; PostScriptPrologFile. It then changes the value, and finally ;; it resets the value back to the original setting. (setq acadObj (vlax-get-acad-object)) (setq preferences (vla-get-Preferences acadObj)) ;; Retrieve the current PostScriptPrologFile value (setq currPostScriptPrologFile (vla-get-PostScriptPrologFile (vla-get-Files preferences))) (if (= currPostScriptPrologFile "") (alert "PostScriptPrologFile is not currently set.") (alert (strcat "The current value for PostScriptPrologFile is " currPostScriptPrologFile)) ) ;; Change the value for PostScriptPrologFile (setq newPostScriptPrologFile "TestPostScriptPrologFile") (vla-put-PostScriptPrologFile (vla-get-Files preferences) newPostScriptPrologFile) (alert (strcat "The new value for PostScriptPrologFile is " newPostScriptPrologFile)) ;; Reset PostScriptPrologFile to its original value (vla-put-PostScriptPrologFile (vla-get-Files preferences) currPostScriptPrologFile) (if (= currPostScriptPrologFile "") (alert "PostScriptPrologFile is reset to NULL.") (alert (strcat "The PostScriptPrologFile value is reset to " currPostScriptPrologFile)) ) ) |
GMT+8, 2024-6-2 20:00
