指定布局或打印配置的旋转角度。 支持的平台:仅窗口 属性值只读:不 类型:枚举acPlotRotation
言论旋转角度相对于对象 WCS 的X轴,从Z轴向下看向原点时,正角逆时针方向移动。 在重新生成图形之前,对此属性的更改将不可见。使用该方法再生图形。Regen 例子工 务 局: Sub Example_PlotRotation() ' This example reads and modifies the PlotRotation ' Layout value. ' When finished, this example resets the value back to ' its original value. Dim ACADLayout As ACADLayout Dim originalValue As Integer ' Get the layout object Set ACADLayout = ThisDrawing.ActiveLayout ' Read and display the original value originalValue = ACADLayout.PlotRotation MsgBox "The PlotRotation value is set to: " & originalValue ' Modify the PlotRotation preference by toggling the value ACADLayout.PlotRotation = ac180degrees MsgBox "The PlotRotation preference has been set to: " & ACADLayout.PlotRotation ' Reset the preference back to its original value ACADLayout.PlotRotation = originalValue MsgBox "The PlotRotation preference was reset back to: " & originalValue End Sub Visual LISP: (vl-load-com) (defun c:Example_PlotRotation() ;; This example reads and modifies the PlotRotation ;; Layout value. ;; When finished, this example resets the value back to ;; its original value. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Get the layout object (setq ACADLayout (vla-get-ActiveLayout doc)) ;; Read and display the original value (setq originalValue (vla-get-PlotRotation ACADLayout)) (alert (strcat "The PlotRotation value is set to: " (itoa originalValue))) ;; Modify the PlotRotation preference by toggling the value (vla-put-PlotRotation ACADLayout ac180degrees) (alert (strcat "The PlotRotation preference has been set to: " (itoa (vla-get-PlotRotation ACADLayout)))) ;; Reset the preference back to its original value (vla-put-PlotRotation ACADLayout originalValue) (alert (strcat "The PlotRotation preference was reset back to: " (itoa originalValue))) ) |
GMT+8, 2024-6-10 18:55
