指定打印日志文件的路径。 支持的平台:仅窗口 属性值只读:不 类型:字符串 打印日志文件的路径。 言论此属性等效于“AutoCAD 选项”对话框设置“打印和发布日志文件位置”。 例子工 务 局: Sub Example_PlotLogFilePath() ' Note: Change the path to a valid folder on your system. Dim MyPreference As AcadPreferencesFiles Set MyPreference = AcadApplication.Preferences.Files MyPreference.PlotLogFilePath = "C:\Plots" End Sub Visual LISP: (vl-load-com) (defun c:Example_PlotLogFilePath() ;; Note: Change the path to a valid folder on your system. (setq acadObj (vlax-get-acad-object)) (setq preferences (vla-get-Preferences acadObj)) (setq MyPreference (vla-get-Files preferences)) (vla-put-PlotLogFilePath MyPreference "C:\\Plots") ) |
GMT+8, 2024-6-2 21:07
