确定是否使用 Shift 键将对象添加到选择集中。 支持的平台:仅窗口 属性值只读:不 类型:布尔
言论此属性的初始值为 False。 注意:此属性的值存储在 PICKADD 系统变量中。
例子工 务 局: Sub Example_PickAdd() ' This example reads and modifies the preference value that controls ' whether objects are added to the selection set using the SHIFT key. ' When finished, this example resets the preference value back to ' its original value. Dim ACADPref As AcadPreferencesSelection Dim originalValue As Variant, newValue As Variant ' Get the selection preferences object Set ACADPref = ThisDrawing.Application.Preferences.Selection ' Read and display the original value originalValue = ACADPref.PickAdd MsgBox "The PickAdd preference is set to: " & originalValue ' Modify the PickAdd preference by toggling the value ACADPref.PickAdd = Not (ACADPref.PickAdd) newValue = ACADPref.PickAdd MsgBox "The PickAdd preference has been set to: " & newValue ' Reset the preference back to its original value ' ' * Note: Comment out this last section to leave the change to ' this preference in effect ACADPref.PickAdd = originalValue MsgBox "The PickAdd preference was reset back to: " & originalValue End Sub Visual LISP: (vl-load-com) (defun c:Example_PickAdd() ;; This example reads and modifies the preference value that controls ;; whether objects are added to the selection set using the SHIFT key. ;; When finished, this example resets the preference value back to ;; its original value. (setq acadObj (vlax-get-acad-object)) (setq preferences (vla-get-Preferences acadObj)) ;; Read and display the original value (setq originalValue (vla-get-PickAdd (vla-get-Selection preferences))) (alert (strcat "The PickAdd preference is set to: " (if (= originalValue :vlax-true) "True" "False"))) ;; Modify the PickAdd preference by toggling the value (vla-put-PickAdd (vla-get-Selection preferences) (if (= originalValue :vlax-true) :vlax-false :vlax-true)) (setq newValue (vla-get-PickAdd (vla-get-Selection preferences))) (alert (strcat "The PickAdd preference has been set to: " (if (= newValue :vlax-true) "True" "False"))) ;; Reset the preference back to its original value ;; ;; * Note: Comment out this last section to leave the change to ;; this preference in effect (vla-put-PickAdd (vla-get-Selection preferences) originalValue) (alert (strcat "The PickAdd preference was reset back to: " (if (= originalValue :vlax-true) "True" "False"))) ) |
GMT+8, 2024-6-2 18:11
