指定用于显示布局或打印配置属性的单位。 支持的平台:仅窗口 属性值只读:不 类型:枚举acPlotPaperUnits
言论此属性确定在用户界面中显示布局或打印配置的单位。此属性不确定 ActiveX 自动化属性的输入或查询单位。所有 ActiveX 自动化属性都以毫米或弧度表示,而不考虑单位设置。 在重新生成图形之前,对此属性的更改将不可见。使用该方法再生图形。Regen 例子工 务 局: Sub Example_PaperUnits() ' This example will access the Layouts collection for the current drawing ' and list basic information about the paper units used for each Layout. Dim Layouts As AcadLayouts, Layout As ACADLayout Dim msg As String Dim Measurement As String ' Get layouts collection from document object Set Layouts = ThisDrawing.Layouts msg = vbCrLf ' Start with a space ' Get the paper units information of every layout in this drawing For Each Layout In Layouts ' Using inches or millimeters? Measurement = IIf(Layout.PaperUnits = acInches, " inches", " millimeters") ' Format for display msg = msg & Layout.name & " is using" & Measurement & vbCrLf Next ' Display paper units information MsgBox "The paper units used in the current drawing are: " & msg End Sub Visual LISP: (vl-load-com) (defun c:Example_PaperUnits() ;; This example will access the Layouts collection for the current drawing ;; and list basic information about the paper units used for each Layout. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Get layouts collection from document object (setq Layouts (vla-get-Layouts doc)) (setq msg "" Measurement "") ;; Get the paper units information of every layout in this drawing (vlax-for Layout Layouts ;; Using inches or millimeters? (setq Measurement (if (= (vla-get-PaperUnits Layout) acInches) " inches" " millimeters")) ;; Format for display (setq msg (strcat msg (vla-get-Name Layout) " is using" Measurement "\n")) ) ;; Display paper units information (alert (strcat "The paper units used in the current drawing are: \n" msg)) ) |
GMT+8, 2024-6-2 18:18
