获取文档的 PaperSpace 集合。 支持的平台:仅窗口 言论没有额外的评论。 例子工 务 局: Sub Example_PaperSpace() ' This example sets the variable pspace to the paper space object collection. Dim pspace As AcadPaperSpace Set pspace = ThisDrawing.PaperSpace End Sub Visual LISP: (vl-load-com) (defun c:Example_PaperSpace() ;; This example sets the variable pspace to the paper space object collection. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (setq pspace (vla-get-PaperSpace doc)) ) |
GMT+8, 2024-6-11 03:11
