获取首选项输出对象。 支持的平台:仅窗口 言论该对象保存存储在注册表中的“选项”对话框中的“输出”选项卡中的所有选项。与图形一起存储的所有选项都可以在对象上找到。PreferencesOutputDatabasePreferences 例子工 务 局: Sub Example_Output() ' This example obtains a reference to the Output Preferences object ' from the Application Preferences object, and reads one of the Output ' preferences Dim ACADPref As AcadPreferencesOutput ' Obtain a reference to the Output Preferences object Set ACADPref = ThisDrawing.Application.preferences.Output MsgBox "You now have access to the properties and methods of the Output Preferences object!" MsgBox "The Output preference DefaultOutputDevice is set to: " & ACADPref.DefaultOutputDevice End Sub Visual LISP: (vl-load-com) (defun c:Example_Output() ;; This example obtains a reference to the Output Preferences object ;; from the Application Preferences object, and reads one of the Output ;; preferences (setq acadObj (vlax-get-acad-object)) (setq preferences (vla-get-Preferences acadObj)) ;; Obtain a reference to the Output Preferences object (alert (strcat "You now have access to the properties and methods of the Output Preferences object!" "\nThe Output preference DefaultOutputDevice is set to: " (vla-get-DefaultOutputDevice (vla-get-Output preferences)))) ) |
GMT+8, 2024-6-11 01:01
