获取首选项打开保存对象。 支持的平台:仅窗口 言论该对象保存存储在注册表中的“选项”对话框中“打开”和“保存”选项卡中的所有选项。与图形一起存储的所有选项都可以在对象上找到。PreferencesOpenSaveDatabasePreferences 例子工 务 局: Sub Example_OpenSave() ' This example obtains a reference to the OpenSave Preferences object ' from the Application Preferences object, and reads one of the OpenSave ' preferences Dim ACADPref As AcadPreferencesOpenSave ' Obtain a reference to the OpenSave Preferences object Set ACADPref = ThisDrawing.Application.preferences.OpenSave MsgBox "You now have access to the properties and methods of the OpenSave Preferences object!" MsgBox "The OpenSave preference TempFileExtension is set to: " & ACADPref.TempFileExtension End Sub Visual LISP: Not available |
GMT+8, 2024-6-10 23:22
