确定指定的弹出菜单是否位于菜单栏上。 支持的平台:仅窗口 属性值只读:是的 类型:布尔
言论没有额外的评论。 例子工 务 局: Sub Example_OnMenuBar() ' This example creates a new menu called TestMenu and inserts a menu item ' into it. The menu is then displayed on the menu bar, and then ' removed from the menu bar. Dim currMenuGroup As acadMenuGroup Set currMenuGroup = ThisDrawing.Application.MenuGroups.Item(0) ' Create the new menu Dim newMenu As AcadPopupMenu Set newMenu = currMenuGroup.Menus.Add("TestMenu") ' Add a menu item to the new menu Dim newMenuItem As AcadPopupMenuItem Dim openMacro As String ' Assign the macro string the VB equivalent of "ESC ESC _open " openMacro = Chr(3) & Chr(3) & Chr(95) & "open" & Chr(32) Set newMenuItem = newMenu.AddMenuItem(newMenu.count + 1, "Open", openMacro) ' Display the menu on the menu bar newMenu.InsertInMenuBar (ThisDrawing.Application.MenuBar.count + 1) GoSub QUERYMENU ' Remove the menu from the menu bar currMenuGroup.Menus.RemoveMenuFromMenuBar ("TestMenu") GoSub QUERYMENU Exit Sub QUERYMENU: If newMenu.OnMenuBar Then MsgBox "The menu called " & newMenu.name & " is on the menu bar." Else MsgBox "The menu called " & newMenu.name & " is not on the menu bar." End If Return End Sub Visual LISP: (vl-load-com) (defun c:Example_OnMenuBar() ;; This example creates a new menu called TestMenu and inserts a menu item ;; into it. The menu is then displayed on the menu bar, and then ;; removed from the menu bar. (setq acadObj (vlax-get-acad-object)) (setq currMenuGroup (vla-Item (vla-get-MenuGroups acadObj) 0)) ;; Create the new menu (setq newMenu (vla-Add (vla-get-Menus currMenuGroup) "TestMenu")) ;; Add a menu item to the new menu ;; Assign the macro string the VB equivalent of "ESC ESC _open " (setq openMacro (strcat (Chr 3) (Chr 3) (Chr 95) "open" (Chr 32))) (setq newMenuItem (vla-AddMenuItem newMenu (1+ (vla-get-Count newMenu)) "Open" openMacro)) ;; Display the menu on the menu bar (vla-InsertInMenuBar newMenu (1+ (vla-get-Count (vla-get-MenuBar acadObj)))) (if (= (vla-get-OnMenuBar newMenu) :vlax-true) (alert (strcat "The menu called " (vla-get-Name newMenu) " is on the menu bar.")) (alert (strcat "The menu called " (vla-get-Name newMenu) " is not on the menu bar.")) ) ;; Remove the menu from the menu bar (vla-RemoveMenuFromMenuBar (vla-get-Menus currMenuGroup) "TestMenu") (if (= (vla-get-OnMenuBar newMenu) :vlax-true) (alert (strcat "The menu called " (vla-get-Name newMenu) " is on the menu bar.")) (alert (strcat "The menu called " (vla-get-Name newMenu) " is not on the menu bar.")) ) ) |
GMT+8, 2024-6-11 05:58
