指定对象捕捉模式的设置。 支持的平台:仅窗口 属性值只读:不 类型:布尔
言论没有额外的评论。 例子工 务 局: Sub Example_ObjectSnapMode() ' This example toggles the setting of the Object Snap Mode. Dim currObjSnapMode As Boolean ' Get the current ObjectSnapMode value currObjSnapMode = ThisDrawing.ObjectSnapMode MsgBox "The object snap mode is currently " & IIf(ThisDrawing.ObjectSnapMode, "on.", "off."), , "ObjectSnapMode Example" ' Change the default ObjectSnapMode value ThisDrawing.ObjectSnapMode = Not (currObjSnapMode) MsgBox "The object snap mode is now " & IIf(ThisDrawing.ObjectSnapMode, "on.", "off."), , "ObjectSnapMode Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_ObjectSnapMode() ;; This example toggles the setting of the Object Snap Mode. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Get the current ObjectSnapMode value (setq currObjSnapMode (vla-get-ObjectSnapMode doc)) (alert (strcat "The object snap mode is currently " (if (= (vla-get-ObjectSnapMode doc) :vlax-true) "on." "off."))) ;; Change the default ObjectSnapMode value (vla-put-ObjectSnapMode doc (if (= (vla-get-ObjectSnapMode doc) :vlax-true) :vlax-false :vlax-true)) (alert (strcat "The object snap mode is now " (if (= (vla-get-ObjectSnapMode doc) :vlax-true) "on." "off."))) ) |
GMT+8, 2024-6-11 02:57
