获取表具有的单元格样式数。 支持的平台:仅窗口 属性值只读:是的 类型:长 值的位置。 言论没有额外的评论。 例子工 务 局: Sub Example_CellStyle() ' This example creates a TableStyle object and sets values for ' the style name and formatting. Dim dictionaries As AcadDictionaries Set dictionaries = ThisDrawing.Database.dictionaries Dim dictObj As AcadDictionary Set dictObj = dictionaries.Item("acad_tablestyle") ' Create the custom TableStyle object in the dictionary Dim keyName As String Dim className As String Dim customObj As IAcadTableStyle keyName = "NewStyle" className = "AcDbTableStyle" Set customObj = dictObj.AddObject(keyName, className) customObj.Name = "NewStyle" customObj.Description = "New Style for My Tables" customObj.CreateCellStyle ("NewTestStyle") Dim cellTestFormat As String customObj.SetFormat2 "NewTestStyle", "test format" customObj.GetFormat2 "NewTestStyle", cellTestFormat MsgBox "Cell Style Name = " & cellTestFormat customObj.RenameCellStyle "NewTestStyle", "NewTestStyle2" customObj.GetFormat2 "NewTestStyle2", cellTestFormat MsgBox "Cell Style Name = " & cellTestFormat Dim uniqueStyleName As String uniqueStyleName = customObj.GetUniqueCellStyleName("testbase") MsgBox "Cell Style Name = " & uniqueStyleName If customObj.GetIsCellStyleInUse("testbase") = False Then MsgBox "That cell style is not being used!" End If customObj.CreateCellStyleFromStyle "TestStyleFromStyle", "NewTestStyle2" customObj.DeleteCellStyle "NewTestStyle2" Dim numOfStyles As Long numOfStyles = customObj.NumCellStyles End Sub Visual LISP: (vl-load-com) (defun c:Example_CellStyle() ;; This example creates a TableStyle object and sets values for ;; the style name and formatting. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (setq dictionaries (vla-get-Dictionaries doc)) (setq dictObj (vla-Item dictionaries "acad_tablestyle")) ;; Create the custom TableStyle object in the dictionary (setq keyName "NewStyle" className "AcDbTableStyle") (setq customObj (vla-AddObject dictObj keyName className)) (vla-put-Name customObj "NewStyle") (vla-put-Description customObj "New Style for My Tables") (vla-CreateCellStyle customObj "NewTestStyle") (setq cellTestFormat "") (vla-SetFormat2 customObj "NewTestStyle" "test format") (vla-GetFormat2 customObj "NewTestStyle" 'cellTestFormat) (alert (strcat "Cell Style Name = " cellTestFormat)) (vla-RenameCellStyle customObj "NewTestStyle" "NewTestStyle2") (vla-GetFormat2 customObj "NewTestStyle2" 'cellTestFormat) (alert (strcat "Cell Style Name = " cellTestFormat)) (setq uniqueStyleName (vla-GetUniqueCellStyleName customObj "testbase")) (alert (strcat "Cell Style Name = " uniqueStyleName)) (if (= (vla-GetIsCellStyleInUse customObj "testbase") :vlax-false) (alert "That cell style is not being used!") ) (vla-CreateCellStyleFromStyle customObj "TestStyleFromStyle" "NewTestStyle2") (vla-DeleteCellStyle customObj "NewTestStyle2") (setq numOfStyles (vla-get-NumCellStyles customObj)) (alert (strcat "Number of Cell Styles = " (itoa numOfStyles))) ) |
GMT+8, 2024-6-2 20:43
