获取多边形网格的顶点数。 支持的平台:仅窗口 属性值只读:是的 类型:长 中的顶点数。PolyfaceMesh 言论没有额外的评论。 例子工 务 局: Sub Example_NumberOfVertices() ' This example creates a PolyFaceMesh and displays the number of vertices it contains Dim vertexList(0 To 17) As Double Dim FaceList(0 To 7) As Integer Dim NewPolyFaceMeshObj As AcadPolyfaceMesh Dim direction(0 To 2) As Double 'Data for new PolyFaceMesh object vertexList(0) = 4: vertexList(1) = 7: vertexList(2) = 0 vertexList(3) = 5: vertexList(4) = 7: vertexList(5) = 0 vertexList(6) = 6: vertexList(7) = 7: vertexList(8) = 0 vertexList(9) = 4: vertexList(10) = 6: vertexList(11) = 0 vertexList(12) = 5: vertexList(13) = 6: vertexList(14) = 0 vertexList(15) = 6: vertexList(16) = 6: vertexList(17) = 6 FaceList(0) = 1: FaceList(1) = 2: FaceList(2) = 5 FaceList(3) = 4: FaceList(4) = 2: FaceList(5) = 3 FaceList(6) = 6: FaceList(7) = 5 ' Create new PolyFaceMesh object Set NewPolyFaceMeshObj = ModelSpace.AddPolyfaceMesh(vertexList, FaceList) NewPolyFaceMeshObj.Update ' Change the viewing direction of the viewport to ' better see the polyface mesh direction(0) = -1: direction(1) = -1: direction(2) = 1 ThisDrawing.ActiveViewport.direction = direction ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport ThisDrawing.Application.ZoomAll ' Display number of vertices in this PolyFaceMesh MsgBox "The new PolyFaceMesh contains " & NewPolyFaceMeshObj.NumberOfVertices & " vertices." End Sub Visual LISP: (vl-load-com) (defun c:Example_NumberOfVertices() ;; This example creates a PolyFaceMesh and displays the number of vertices it contains (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Data for new PolyFaceMesh object (setq vertexList (vlax-make-safearray vlax-vbDouble '(0 . 17))) (vlax-safearray-fill vertexList '(4 7 0 5 7 0 6 7 0 4 6 0 5 6 0 6 6 6 ) ) (setq FaceList (vlax-make-safearray vlax-vbInteger '(0 . 7))) (vlax-safearray-fill FaceList '(1 2 5 4 2 3 6 5 ) ) ;; Create new PolyFaceMesh object (setq modelSpace (vla-get-ModelSpace doc)) (setq NewPolyFaceMeshObj (vla-AddPolyfaceMesh modelSpace vertexList FaceList)) (vla-Update NewPolyFaceMeshObj) ;; Change the viewing direction of the viewport to ;; better see the polyface mesh (setq direction (vlax-3d-point -1 -1 1)) (setq activeViewport (vla-get-ActiveViewport doc)) (vla-put-Direction activeViewport direction) (vla-put-ActiveViewport doc activeViewport) (vla-ZoomAll acadObj) ;; Display number of vertices in this PolyFaceMesh (alert (strcat "The new PolyFaceMesh contains " (itoa (vla-get-NumberOfVertices NewPolyFaceMeshObj)) " vertices.")) ) |
GMT+8, 2024-6-11 04:58
