获取样条的控制点数。 支持的平台:仅窗口 属性值只读:是的 类型:整数 样条的控制点数。 言论控制点通过向样条曲线的一部分添加权重来微调样条定义。 您可以使用该方法查询控制点的当前位置。您可以使用该方法为控制点设置新的坐标位置。您可以使用该方法为控制点设置新的权重。GetControlPointSetControlPointSetWeight 例子工 务 局: Sub Example_NumberOfControlPoints() ' This example creates a spline object in model space. ' It then finds the number of control points for that spline. ' Create the spline Dim splineObj As AcadSpline Dim startTan(0 To 2) As Double Dim endTan(0 To 2) As Double Dim fitPoints(0 To 8) As Double startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0 endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0 fitPoints(0) = 1: fitPoints(1) = 1: fitPoints(2) = 0 fitPoints(3) = 5: fitPoints(4) = 5: fitPoints(5) = 0 fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0 Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan) ZoomAll MsgBox "The Spline has " & splineObj.NumberOfControlPoints & " control points.", , "NumberOfControlPoints Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_NumberOfControlPoints() ;; This example creates a spline object in model space. ;; It then finds the number of control points for that spline. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Create the spline (setq startTan (vlax-3d-point 0.5 0.5 0) endTan (vlax-3d-point 0.5 0.5 0) fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8))) (vlax-safearray-fill fitPoints '(1 1 0 5 5 0 10 0 0 ) ) (setq modelSpace (vla-get-ModelSpace doc)) (setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan)) (vla-ZoomAll acadObj) (alert (strcat "The Spline has " (itoa (vla-get-NumberOfControlPoints splineObj)) " control points.")) ) |
GMT+8, 2024-6-10 17:06
