指定多边形网格是否在 N 个方向上闭合。 支持的平台:仅窗口 属性值只读:不 类型:布尔
言论如果关闭,它将被视为从最后一列到第一列的连续。如果打开,它将被视为最后一列和第一列之间的不连续。PolygonMeshPolygonMesh 例子工 务 局: Sub Example_NClose() ' This example creates a 4 X 4 polygonmesh in model space. ' It then closes the polymesh in the 'N' direction. Dim meshObj As AcadPolygonMesh Dim mSize, nSize, count As Integer Dim points(0 To 47) As Double ' Create the matrix of points points(0) = 2: points(1) = 2: points(2) = 1 points(3) = 2.5: points(4) = 2: points(5) = 0 points(6) = 5: points(7) = 2: points(8) = 0 points(9) = 5.5: points(10) = 2: points(11) = 1 points(12) = 2: points(13) = 4: points(14) = 0.5 points(15) = 2.5: points(16) = 4: points(17) = 0 points(18) = 5: points(19) = 4: points(20) = 0 points(21) = 5.5: points(22) = 4: points(23) = 0.5 points(24) = 2: points(25) = 6: points(26) = 0.5 points(27) = 2.5: points(28) = 6: points(29) = 0 points(30) = 5: points(31) = 6: points(32) = 0 points(33) = 5.5: points(34) = 6: points(35) = 0.5 points(36) = 2: points(37) = 8: points(38) = 1 points(39) = 2.5: points(40) = 8: points(41) = 0 points(42) = 5: points(43) = 8: points(44) = 0 points(45) = 5.5: points(46) = 8: points(47) = 1 mSize = 4: nSize = 4 ' Create a 3Dmesh in model space Set meshObj = ThisDrawing.ModelSpace.Add3DMesh(mSize, nSize, points) ' Change the viewing direction of the viewport to better see the cylinder Dim NewDirection(0 To 2) As Double NewDirection(0) = -1: NewDirection(1) = -1: NewDirection(2) = 1 ThisDrawing.ActiveViewport.direction = NewDirection ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport ZoomAll ' Close the polymesh in the 'M' direction MsgBox "The polymesh is " & IIf(meshObj.NClose, "closed", "open") & " in the 'N' direction.", , "NClose Example" meshObj.NClose = True ThisDrawing.Regen acActiveViewport MsgBox "The polymesh is " & IIf(meshObj.NClose, "closed", "open") & " in the 'N' direction.", , "NClose Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_NClose() ;; This example creates a 4 X 4 polygonmesh in model space. ;; It then closes the polymesh in the 'N' direction. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Create the matrix of points (setq points (vlax-make-safearray vlax-vbDouble '(0 . 47))) (vlax-safearray-fill points '(2 2 1 2.5 2 0 5 2 0 5.5 2 1 2 4 0.5 2.5 4 0 5 4 0 5.5 4 0.5 2 6 0.5 2.5 6 0 5 6 0 5.5 6 0.5 2 8 1 2.5 8 0 5 8 0 5.5 8 1 ) ) (setq mSize 4 nSize 4) ;; Create a 3Dmesh in model space (setq modelSpace (vla-get-ModelSpace doc)) (setq meshObj (vla-Add3DMesh modelSpace mSize nSize points)) ;; Change the viewing direction of the viewport to better see the cylinder (setq NewDirection (vlax-3d-point -1 -1 1)) (setq activeViewport (vla-get-ActiveViewport doc)) (vla-put-Direction activeViewport NewDirection) (vla-put-ActiveViewport doc activeViewport) (vla-ZoomAll acadObj) ;; Close the polymesh in the 'N' direction (alert (strcat "The polymesh is " (if (= (vla-get-NClose meshObj) :vlax-true) "closed" "open") " in the 'N' direction.")) (vla-put-NClose meshObj :vlax-true) (vla-Regen doc acActiveViewport) (alert (strcat "The polymesh is " (if (= (vla-get-NClose meshObj) :vlax-true) "closed" "open") " in the 'N' direction.")) ) |
GMT+8, 2024-6-11 02:45
