指定材料的名称。 支持的平台:仅窗口 属性值只读:不 类型:字符串 材料的名称。 言论没有额外的评论。 例子工 务 局: Sub Example_AddMaterial() Dim oMaterial As AcadMaterial Dim oMaterials As AcadMaterials Set oMaterial = ThisDrawing.Materials.Add("TestMaterial") oMaterial.Description = "This material demonstrates how to add a material to a database." ThisDrawing.ActiveMaterial = oMaterial ' Display the name and description of the layer MsgBox oMaterial.Name & " has been added." & vbCrLf & _ "Name: " & vbCrLf & oMaterial.Name & vbCrLf & vbCrLf & _ "Description: " & vbCrLf & _ oMaterial.Description End Sub Visual LISP: (vl-load-com) (defun c:Example_Materials() (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (setq oMaterial (vla-Add (vla-get-Materials doc) "TestMaterial")) (vla-put-Description oMaterial "This material demonstrates how to add a material to a database.") (vla-put-ActiveMaterial doc oMaterial) ;; Display the status of the new layer (alert (strcat (vla-get-Name oMaterial) " has been added." "\nName: " (vla-get-Name oMaterial) "\nDescription: " (vla-get-Description oMaterial))) ) |
GMT+8, 2024-6-2 22:02
