指定用于拼写检查的当前词典。 支持的平台:仅窗口 属性值只读:不 类型:字符串 要使用的拼写检查词典。 言论没有额外的评论。 例子工 务 局: Sub Example_MainDictionary() ' This example returns the current setting of ' MainDictionary. It then changes the value, and finally ' it resets the value back to the original setting. Dim preferences As AcadPreferences Dim currMainDictionary As String Dim newMainDictionary As String Set preferences = ThisDrawing.Application.preferences ' Retrieve the current MainDictionary value currMainDictionary = preferences.Files.MainDictionary MsgBox "The current value for MainDictionary is " & currMainDictionary, vbInformation, "MainDictionary Example" ' Change the value for MainDictionary newMainDictionary = "TestMainDictionary" preferences.Files.MainDictionary = newMainDictionary MsgBox "The new value for MainDictionary is " & newMainDictionary, vbInformation, "MainDictionary Example" ' Reset MainDictionary to its original value preferences.Files.MainDictionary = currMainDictionary MsgBox "The MainDictionary value is reset to " & currMainDictionary, vbInformation, "MainDictionary Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_MainDictionary() ;; This example returns the current setting of ;; MainDictionary. It then changes the value, and finally ;; it resets the value back to the original setting. (setq acadObj (vlax-get-acad-object)) (setq preferences (vla-get-Preferences acadObj)) ;; Retrieve the current MainDictionary value (setq currMainDictionary (vla-get-MainDictionary (vla-get-Files preferences))) (alert (strcat "The current value for MainDictionary is " currMainDictionary)) ;; Change the value for MainDictionary (setq newMainDictionary "TestMainDictionary") (vla-put-MainDictionary (vla-get-Files preferences) newMainDictionary) (alert (strcat "The new value for MainDictionary is " newMainDictionary)) ;; Reset MainDictionary to its original value (vla-put-MainDictionary (vla-get-Files preferences) currMainDictionary) (alert (strcat "The MainDictionary value is reset to " currMainDictionary)) ) |
GMT+8, 2024-6-2 20:34
