指定透视查看中使用的镜头长度。 支持的平台:仅窗口 属性值只读:不 类型:双 镜头的长度(以毫米为单位)。 言论注意:此属性的值存储在 LENSLENGTH 系统变量中。
例子工 务 局: Sub Example_LensLength() ' This example creates a new paper space viewport. ' It then displays the lens length of the viewport. Dim pviewportObj As AcadPViewport Dim center(0 To 2) As Double Dim width As Double Dim height As Double ' Define the paper space viewport center(0) = 3: center(1) = 3: center(2) = 0 width = 40 height = 40 ' Change from model space to paper space ThisDrawing.ActiveSpace = acPaperSpace ' Create the paper space viewport Set pviewportObj = ThisDrawing.PaperSpace.AddPViewport(center, width, height) pviewportObj.DISPLAY True ThisDrawing.mspace = True ThisDrawing.ActivePViewport = pviewportObj ThisDrawing.Regen acAllViewports ' Find the Lens Length for the viewport Dim lenslgnth As Double lenslgnth = pviewportObj.LensLength MsgBox "The lens length of the paperspace viewport is " & pviewportObj.LensLength, , "LensLength Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_LensLength() ;; This example creates a new paper space viewport. ;; It then displays the lens length of the viewport. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Define the paper space viewport (setq center (vlax-3d-point 3 3 0) width 40 height 40) ;; Change from model space to paper space (vla-put-ActiveSpace doc acPaperSpace) ;; Create the paper space viewport (setq paperSpace (vla-get-PaperSpace doc)) (setq pviewportObj (vla-AddPViewport paperSpace center width height)) (vla-Display pviewportObj :vlax-true) (vla-put-MSpace doc :vlax-true) (vla-put-ActivePViewport doc pviewportObj) (vla-Regen doc acAllViewports) ;; Find the Lens Length for the viewport (setq lenslgnth (vla-get-LensLength pviewportObj)) (alert (strcat "The lens length of the paperspace viewport is " (rtos lenslgnth 2))) ) |
GMT+8, 2024-6-10 23:09
